When I try to import an ext2fs disk (using the GUI) on TrueNAS-12.0-RELEASE, I get a FAILED message "Mount failed (exit code 1): mount: /dev/da8s1: Invalid argument".
Under More info..., I see:
I was able to import this disk successfully under previous versions of FreeNAS.
Any help much appreciated.
Thanks.
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
await self.future
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 397, in __run_body
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/import_disk.py", line 53, in import_disk
async with await self.middleware.call('pool.import_disk_mount_fs_context_manager', device, src,
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/import_disk_freebsd.py", line 96, in __aenter__
await mount(self.device, self.path, *self.args, **self.kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/import_disk_freebsd.py", line 54, in mount
raise ValueError("Mount failed (exit code {0}):\n{1}{2}" .format(
ValueError: Mount failed (exit code 1):
Thanks.
