Mount Failed importing ext2fs disk on TrueNAS Core
DTM
When I try to import an ext2fs disk (using the GUI) on TrueNAS-12.0-RELEASE, I get a FAILED message "Mount failed (exit code 1): mount: /dev/da8s1: Invalid argument".
Under More info..., I see:
Error: Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run await self.future File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 397, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/import_disk.py", line 53, in import_disk async with await self.middleware.call('pool.import_disk_mount_fs_context_manager', device, src, File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/import_disk_freebsd.py", line 96, in __aenter__ await mount(self.device, self.path, *self.args, **self.kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/import_disk_freebsd.py", line 54, in mount raise ValueError("Mount failed (exit code {0}):\n{1}{2}" .format( ValueError: Mount failed (exit code 1): mount: /dev/da8s1: Invalid argument
I was able to import this disk successfully under previous versions of FreeNAS.
Any help much appreciated.
Thanks.
DTM
In case anyone else has this issue, upgrading to 12.0 U1 fixes it.
