I have 2 TrueNAS Core systems connected via VPN. I would like to connect some of the pools from each system to the other, or would like to figure out howto mount on boot a share (NFS, or some other type native to BSD) without the use of a manual script run via cron.
Yes I can mount NFS shares via CLI, but those are only good until the next reboot of a system, than I have to manually mount those shares again. Not desired, nor ideal.
I looked into running TrueCommand, but that requires 3 sets of hardware not 2, and everything has to be on the same subnet, so no VPN, thus no remote location for the data points.
Sometime in 2022 they 2 TrueNAS systems will be in the same location, but that is still only 2 sets of hardware not 3.
The data sets (pools) that are looked to be shared between the 2 systems are only semi-redundant. This is not a mirroring setup. It is a data pool sharing system. Data on TN2 and TN1 is not 100% the same. That is intentional, thus data on TN2 might be needed by TN1 and vis a vis.
What are the best options for this type of connected data sharing?
Thank you
Thank you
