kazooless
- Aug 9, 2013
My consumer grade motherboard made it almost 5 years! Unfortunately, it is now dead. :(
I'm reading the Hardware resource PDF and will most likely replace my board with a properly recommended board. However, so far I'm not seeing any with an MSATA slot. I always hated the USB dongle sticking out of the case, so I installed a Kingston 30GB MSATA drive directly on the motherboard. That is where my config is and such, and even though every upgrade I ran the backup so I could revert, I didn't copy a configuration externally to that drive. (Here is the drive: https://smile.amazon.com/gp/product/B00DHWE3G0/ref=od_aui_detailpages00?ie=UTF8&psc=1)
So, if I get a new board that doesn't have an MSATA connection, obviously I can do a clean install of FreeNAS and import the disks. I had several jails installed and such. Will I have to recreate all of that? Or will I be able to find a config on the drives and import?
