depasseg
FreeNAS Replicant
- Sep 16, 2014
Any compatibility or other issues?
Thanks,
Greg
SUPERMICRO 5028R-E1CR12L Chassis
http://www.supermicro.com/products/system/2U/5028/SSG-5028R-E1CR12L.cfm
SuperMicro X10SRH-CLN4F Motherboard
http://www.supermicro.com/products/motherboard/Xeon/C600/X10SRH-CLN4F.cfm
128GB DDR4 2133MHz ECC RDIMM
Intel Xeon E5-2637 v3 (4C, 3.5GHz, 15MB)
12x WD RE SAS 4 TB Enterprise Hard Drive: 3.5 Inch, 7200 RPM, SAS, 32 MB Cache - WD4001FYYG View: http://smile.amazon.com/dp/B0090UGQ2C/ref=pe_385040_30332200_TE_item
2x Intel 2.5-Inch 200 GB Internal Solid State Drive SSDSC2BA200G301
View: http://smile.amazon.com/dp/B00A8NWD68/ref=pe_385040_30332200_TE_item
I also have an M1015 (as a backup to connect to the drives, in case I have problems with the LSI 3008.)
Thanks,
Greg
