MotherBoard dead
aymen
Dear FreeNAS lovers
My system was working fine but the Air Conditioner drops same of water in to the Board.
so now it tray to install it to anther motherboard but it ....
and say status: The pool was last accessed by another system. as shown down
need your help
[root@freenas ~]# zpool import
  pool: BackupServer
  id:
  state: UNAVAIL
action: The pool cannot be imported due to damaged devices or data.
  see: http://illumos.org/msg/ZFS-8000-EY
  BackupServer  UNAVAIL  insufficient replicas
  raidz1-0  UNAVAIL  insufficient replicas
  gptid/905bb162-2507-11e5-a8df-94de80c168f9  ONLINE
  gptid/90aebf04-2507-11e5-a8df-94de80c168f9  ONLINE
  2172289646765970638  UNAVAIL  cannot open
  7483978254816060961  UNAVAIL  cannot open
  gptid/91bcb5a6-2507-11e5-a8df-94de80c168f9  ONLINE
[root@freenas ~]# camcontrol devlist
<ST3500630AS 3.AAK>				at scbus0 target 0 lun 0 (pass0,ada0)
<ST4000VN000-1H4168 SC46>		  at scbus3 target 0 lun 0 (pass1,ada1)
<ST4000VN000-1H4168 SC46>		  at scbus3 target 1 lun 0 (pass2,ada2)
<ST4000VN000-1H4168 SC46>		  at scbus4 target 0 lun 0 (pass3,ada3)
<ST4000VN000-1H4168 SC46>		  at scbus4 target 1 lun 0 (pass4,ada4)
<ST4000VN000-1H4168 SC46>		  at scbus5 target 0 lun 0 (pass5,ada5)
[root@freenas ~]# gpart show
=>	   34  976770988  ada0  GPT  (465G)
		 34	   1024	 1  bios-boot  (512k)
	   1058		  6		- free -  (3.0k)
	   1064  976769952	 2  freebsd-zfs  (465G)
  976771016		  6		- free -  (3.0k)
=>		34  7814037101  ada2  GPT  (3.7T)
		  34		  94		- free -  (47k)
		 128	 4194304	 1  freebsd-swap  (2.0G)
	 4194432  7809842696	 2  freebsd-zfs  (3.7T)
  7814037128		   7		- free -  (3.5k)
=>		34  7814037101  ada3  GPT  (3.7T)
=>		34  7814037101  ada5  GPT  (3.7T)
Arman
Dear FreeNAS lovers
need your help
  pool: BackupServer
  id:
  state: UNAVAIL
Try forcing the import by doing
zpool -f import
I forgot where exactly you put the
-f
but try putting it in the import command.
zpool -f import
-f
Won't work without at least one of the missing drives.
aymen
now i replace the 2nd board and usb cable
<ST4000VN000-1H4168 SC46>		  at scbus4 target 0 lun 0 (ada0,pass0)
<ST4000VN000-1H4168 SC46>		  at scbus4 target 1 lun 0 (ada1,pass1)
<ST4000VN000-1H4168 SC46>		  at scbus5 target 0 lun 0 (ada2,pass2)
<ST4000VN000-1H4168 SC46>		  at scbus5 target 1 lun 0 (ada3,pass3)
<ST4000VN000-1H4168 SC46>		  at scbus7 target 0 lun 0 (ada4,pass4)
<TOSHIBA TransMemory 1.00>		 at scbus9 target 0 lun 0 (pass5,da0)
[root@freenas ~]# zpool import -f (now nothing happen)
[root@freenas ~]# glabel status
									  Name  Status  Components
gptid/a165098b-5693-11e6-995e-001d7d02c19d	 N/A  da0p1
gptid/a16f6a9f-5693-11e6-995e-001d7d02c19d	 N/A  da0p2
[root@freenas ~]# zpool list
NAME		   SIZE  ALLOC   FREE  EXPANDSZ   FRAG	CAP  DEDUP  HEALTH  ALTROOT
freenas-boot  14.4G  1.21G  13.2G		 -	  -	 8%  1.00x  ONLINE  -
gpsguy
Active Member
What USB cable?
Please give us detailed specs on your replacement machine. How are the disks connected?
aymen
Damage Board
http://www.gigabyte.com/products/product-page.aspx?pid=4389#sp
this the 3nd Board
https://www.asus.com/Motherboards/RAMPAGE_II_EXTREME/specifications/
normal USB on the MotherBoard only
This only for testing to recover [emoji12]
joeschmuck
Old Man
First of all, how much RAM do you have in your Asus motherboard? You want to ensure you have 8GB RAM if you are going to use FreeNAS for troubleshooting, even if it appears to work fine with less.
Next, stop trying to import using the -f parameter. Way too many people jump to this and can cause more damage. First lets check out your hard drives and ensure they are healthy. Run a SMART Short test (takes about 2 minutes) and check the status, if all looks good, run a SMART Long test (take generally 2+ hours). If that looks good then you can move forward on the troubleshooting.
The next steps would be to identify exactly which drives (by serial number) are working and which are not. For the drives that are failing to work, how are they failing is the question? Are they not seen at all by the system, in which you wouldn't be able to run a SMART test on them, or does it look fine and can communicate fine but maybe you data is gone. The Hard Drive Troubleshooting Guide will tell you how to run the SMART tests (link in my signature).
You could have a real issue, that being two hard drives that have failed or corrupt data.
aymen
I am running 12GB RAM
Disk 1 ,2,3,4,5
This Short test
recommended polling time:		(   2) minutes.
SCT capabilities:			  (0x10bd) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   114   099   006	Pre-fail  Always	   -	   83482048
  3 Spin_Up_Time			0x0003   093   091   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   103
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   075   060   030	Pre-fail  Always	   -	   32572731
  9 Power_On_Hours		  0x0032   096   096   000	Old_age   Always	   -	   3604
10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   107
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0
189 High_Fly_Writes		 0x003a   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0022   072   052   045	Old_age   Always	   -	   28 (Min/Max 27/28)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   28
193 Load_Cycle_Count		0x0032   070   070   000	Old_age   Always	   -	   60070
194 Temperature_Celsius	 0x0022   028   048   000	Old_age   Always	   -	   28 (0 16 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	  3604		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
and the long test in process but I will be out of town for 1 day
thank you to all
I will be back to continue helping ;p
aymen
all disk ok !
what to do ? :(
Disk 1
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 83491888
7 Seek_Error_Rate 0x000f 075 060 030 Pre-fail Always - 32573673
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3649
190 Airflow_Temperature_Cel 0x0022 075 052 045 Old_age Always - 25 (Min/Max 25/31)
194 Temperature_Celsius 0x0022 025 048 000 Old_age Always - 25 (0 16 0 0 0)
No Errors Logged
# 1 Extended offline Completed without error 00% 3612 -
# 2 Short offline Completed without error 00% 3604 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Disk 2
1 Raw_Read_Error_Rate 0x000f 115 099 006 Pre-fail Always - 91487440
3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 98
7 Seek_Error_Rate 0x000f 075 060 030 Pre-fail Always - 32552567
190 Airflow_Temperature_Cel 0x0022 075 055 045 Old_age Always - 25 (Min/Max 25/30)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 24
193 Load_Cycle_Count 0x0032 070 070 000 Old_age Always - 60231
194 Temperature_Celsius 0x0022 025 045 000 Old_age Always - 25 (0 16 0 0 0)
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 274
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Disk 3
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 159433408
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 104
7 Seek_Error_Rate 0x000f 075 060 030 Pre-fail Always - 32295984
190 Airflow_Temperature_Cel 0x0022 075 050 045 Old_age Always - 25 (Min/Max 25/30)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 27
193 Load_Cycle_Count 0x0032 071 071 000 Old_age Always - 59928
194 Temperature_Celsius 0x0022 025 050 000 Old_age Always - 25 (0 16 0 0 0)
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Disk 4
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 218831096
7 Seek_Error_Rate 0x000f 075 060 030 Pre-fail Always - 32894066
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3624
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 101
190 Airflow_Temperature_Cel 0x0022 075 057 045 Old_age Always - 25 (Min/Max 25/30)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 23
193 Load_Cycle_Count 0x0032 071 071 000 Old_age Always - 59801
194 Temperature_Celsius 0x0022 025 043 000 Old_age Always - 25 (0 16 0 0 0)
No Errors Logged
# 1 Extended offline Completed without error 00% 3587 -
# 2 Short offline Completed without error 00% 3579 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Disk 5
1 Raw_Read_Error_Rate 0x000f 115 099 006 Pre-fail Always - 98667600
7 Seek_Error_Rate 0x000f 075 060 030 Pre-fail Always - 32582000
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 108
190 Airflow_Temperature_Cel 0x0022 075 051 045 Old_age Always - 25 (Min/Max 25/30)
193 Load_Cycle_Count 0x0032 070 070 000 Old_age Always - 60008
194 Temperature_Celsius 0x0022 025 049 000 Old_age Always - 25 (0 16 0 0 0)
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
<ST4000VN000-1H4168 SC46>		  at scbus4 target 0 lun 0 (pass0,ada0)
<ST4000VN000-1H4168 SC46>		  at scbus4 target 1 lun 0 (pass1,ada1)
<ST4000VN000-1H4168 SC46>		  at scbus5 target 0 lun 0 (pass2,ada2)
<ST4000VN000-1H4168 SC46>		  at scbus5 target 1 lun 0 (pass3,ada3)
<ST4000VN000-1H4168 SC46>		  at scbus7 target 0 lun 0 (pass4,ada4)
joeschmuck
Old Man
So, all your SMART tests looked good. Next time, please post the serial numbers of the drives or at least the last 4 digits. It will help us keep things straight.
What is the output of "gpart show" and "zpool import" and "dmesg"? I'm asking you to do this again.
aymen
when enter the code zpool import now nothing happen :( at all
=> 34 30297149 da0 GPT (14G)
34 1024 1 bios-boot (512K)
1058 6 - free - (3.0K)
1064 30296112 2 freebsd-zfs (14G)
30297176 7 - free - (3.5K)
[root@freenas ~]# dmesg
Copyright (c) 1992-2016 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 10.3-STABLE #0 r295946+1805185(9.10.2-STABLE): Wed Jan 11 17:12:42 UTC 2017
root@gauntlet:/freenas-9.10-releng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64 amd64
FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
CPU: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (3000.06-MHz K8-class CPU)
Origin="GenuineIntel" Id=0x10676 Family=0x6 Model=0x17 Stepping=6
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,
HTT,TM,PBE>
Features2=0x8e3fd<SSE3,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,SSE4.1>
AMD Features=0x20100800<SYSCALL,NX,LM>
AMD Features2=0x1<LAHF>
VT-x: HLT,PAUSE
TSC: P-state invariant, performance statistics
real memory = 9663676416 (9216 MB)
avail memory = 8256737280 (7874 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <GBT GBTUACPI>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
random: <Software, Yarrow> initialized
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0: Changing APIC ID to 2
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
aesni0: No AESNI support.
padlock0: No ACE support.
cryptosoft0: <software crypto> on motherboard
acpi0: <GBT GBTUACPI> on motherboard
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 0,8 on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 450
Event timer "HPET1" frequency 14318180 Hz quality 440
Event timer "HPET2" frequency 14318180 Hz quality 440
Event timer "HPET3" frequency 14318180 Hz quality 440
atrtc0: <AT realtime clock> port 0x70-0x73 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
acpi_button0: <Power Button> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <PCI bus> on pcib1
pcib2: <PCI-PCI bridge> at device 0.0 on pci1
pci2: <PCI bus> on pcib2
pcib3: <PCI-PCI bridge> at device 0.0 on pci2
pci3: <PCI bus> on pcib3
vgapci0: <VGA-compatible display> port 0xa000-0xa07f mem 0xe6000000-0xe6ffffff,0xc0000000-0xcfffffff,0xe4000000-0xe5ffffff irq 16 at
device 0.0 on pci3
pcib4: <PCI-PCI bridge> at device 2.0 on pci2
pci4: <PCI bus> on pcib4
vgapci1: <VGA-compatible display> port 0xb000-0xb07f mem 0xea000000-0xeaffffff,0xd0000000-0xdfffffff,0xe8000000-0xe9ffffff irq 18 at
device 0.0 on pci4
vgapci1: Boot video device
uhci0: <Intel 82801I (ICH9) USB controller> port 0xe100-0xe11f irq 16 at device 26.0 on pci0
uhci0: LegSup = 0x2f00
usbus0 on uhci0
uhci1: <Intel 82801I (ICH9) USB controller> port 0xe200-0xe21f irq 21 at device 26.1 on pci0
uhci1: LegSup = 0x2f00
usbus1 on uhci1
uhci2: <Intel 82801I (ICH9) USB controller> port 0xe000-0xe01f irq 18 at device 26.2 on pci0
uhci2: LegSup = 0x2f00
usbus2 on uhci2
ehci0: <Intel 82801I (ICH9) USB 2.0 controller> mem 0xee104000-0xee1043ff irq 18 at device 26.7 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib5: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci6: <ACPI PCI bus> on pcib6
ahci0: <JMicron JMB363 AHCI SATA controller> mem 0xee000000-0xee001fff irq 19 at device 0.0 on pci6
ahci0: AHCI v1.00 with 2 3Gbps ports, Port Multiplier supported
ahci0: quirks=0x1<NOFORCE>
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
atapci0: <JMicron JMB363 UDMA133 controller> port 0xc000-0xc007,0xc100-0xc103,0xc200-0xc207,0xc300-0xc303,0xc400-0xc40f irq 16 at de
vice 0.1 on pci6
ata2: <ATA channel> at channel 0 on atapci0
pcib7: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci7: <ACPI PCI bus> on pcib7
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xd000-0xd0ff mem 0xed000000-0xed000fff irq 16 at device 0.0 o
n pci7
re0: Using 1 MSI message
re0: Chip rev. 0x38000000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1
000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Using defaults for TSO: 65518/35/2048
re0: Ethernet address: 00:00:00:00:00:00
uhci3: <Intel 82801I (ICH9) USB controller> port 0xe300-0xe31f irq 23 at device 29.0 on pci0
usbus4 on uhci3
uhci4: <Intel 82801I (ICH9) USB controller> port 0xe400-0xe41f irq 19 at device 29.1 on pci0
usbus5 on uhci4
uhci5: <Intel 82801I (ICH9) USB controller> port 0xe500-0xe51f irq 18 at device 29.2 on pci0
usbus6 on uhci5
ehci1: <Intel 82801I (ICH9) USB 2.0 controller> mem 0xee105000-0xee1053ff irq 23 at device 29.7 on pci0
usbus7: EHCI version 1.0
usbus7 on ehci1
pcib8: <ACPI PCI-PCI bridge> at device 30.0 on pci0
pci8: <ACPI PCI bus> on pcib8
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci1: <Intel ICH9 AHCI SATA controller> port 0xe600-0xe607,0xe700-0xe703,0xe800-0xe807,0xe900-0xe903,0xea00-0xea1f mem 0xee106000-0
xee1067ff irq 19 at device 31.2 on pci0
ahci1: AHCI v1.20 with 6 3Gbps ports, Port Multiplier supported
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
ahcich4: <AHCI channel> at channel 2 on ahci1
ahcich5: <AHCI channel> at channel 3 on ahci1
ahcich6: <AHCI channel> at channel 4 on ahci1
ahcich7: <AHCI channel> at channel 5 on ahci1
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
ichwd0: <Intel ICH9R watchdog timer> on isa0
orm0: <ISA Option ROMs> at iomem 0xd0000-0xd1fff,0xd2000-0xd4fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
acpi_perf0: <ACPI CPU Frequency Control> on cpu0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
est: CPU supports Enhanced Speedstep, but is not recognized.
est: cpu_vendor GenuineIntel, msr 61a092006000920
device_attach: est1 attach returned 6
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
random: unblocking device.
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 12Mbps Full Speed USB v1.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 12Mbps Full Speed USB v1.0
usbus6: 12Mbps Full Speed USB v1.0
usbus7: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen4.1: <Intel> at usbus4
uhub1: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen3.1: <Intel> at usbus3
uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ugen2.1: <Intel> at usbus2
uhub3: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen1.1: <Intel> at usbus1
uhub4: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus1
ugen7.1: <Intel> at usbus7
uhub5: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus7
ugen6.1: <Intel> at usbus6
uhub6: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus6
ugen5.1: <Intel> at usbus5
uhub7: <Intel UHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
uhub1: 2 ports with 2 removable, self powered
uhub0: 2 ports with 2 removable, self powered
uhub4: 2 ports with 2 removable, self powered
uhub3: 2 ports with 2 removable, self powered
uhub7: 2 ports with 2 removable, self powered
uhub6: 2 ports with 2 removable, self powered
uhub2: 6 ports with 6 removable, self powered
uhub5: 6 ports with 6 removable, self powered
ugen7.2: <TOSHIBA> at usbus7
umass0: <TOSHIBA TransMemory, class 0/0, rev 2.00/1.00, addr 2> on usbus7
umass0: SCSI over Bulk-Only; quirks = 0xc100
umass0:10:0:-1: Attached to scbus10
ada0 at ahcich2 bus 0 scbus3 target 0 lun 0
ada0: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
ada0: Serial Number Z3041F8X
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 3815446MB (7814035055 512 byte sectors)
ada0: Previously was known as ad10
ada1 at ahcich3 bus 0 scbus4 target 0 lun 0
ada1: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
ada1: Serial Number Z3041XC1
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 3815446MB (7814035055 512 byte sectors)
ada1: Previously was known as ad12
ada2 at ahcich4 bus 0 scbus5 target 0 lun 0
ada2: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
ada2: Serial Number Z3041XQY
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 3815446MB (7814035055 512 byte sectors)
ada2: Previously was known as ad14
ada3 at ahcich5 bus 0 scbus6 target 0 lun 0
ada3: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
ada3: Serial Number Z3041FLM
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 3815446MB (7814035055 512 byte sectors)
ada3: Previously was known as ad16
ada4 at ahcich7 bus 0 scbus8 target 0 lun 0
ada4: <ST4000VN000-1H4168 SC46> ACS-2 ATA SATA 3.x device
ada4: Serial Number Z3041YCB
ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 3815446MB (7814035055 512 byte sectors)
ada4: Previously was known as ad20
da0 at umass-sim0 bus 0 scbus10 target 0 lun 0
da0: <TOSHIBA TransMemory 1.00> Removable Direct Access SPC-2 SCSI device
da0: Serial Number C412F52D6C89C01100023EA3
da0: 40.000MB/s transfers
da0: 14793MB (30297216 512 byte sectors)
da0: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
GEOM: ada0: corrupt or invalid GPT detected.
GEOM: ada0: GPT rejected -- may not be recoverable.
SMP: AP CPU #1 Launched!
Timecounter "TSC-low" frequency 1500028807 Hz quality 1000
GEOM: ada1: corrupt or invalid GPT detected.
GEOM: ada1: GPT rejected -- may not be recoverable.
GEOM: ada2: corrupt or invalid GPT detected.
GEOM: ada2: GPT rejected -- may not be recoverable.
GEOM: ada3: corrupt or invalid GPT detected.
GEOM: ada3: GPT rejected -- may not be recoverable.
GEOM: ada4: corrupt or invalid GPT detected.
GEOM: ada4: GPT rejected -- may not be recoverable.
Trying to mount root from zfs:freenas-boot/ROOT/9.10.2-U1 []...
GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7)
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/2/40/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/40/0x67
re0: link state changed to DOWN
vboxdrv: fAsync=0 offMin=0x29a offMax=0xb9a
pid 1313 (syslog-ng), uid 0: exited on signal 6 (core dumped)
Waiting (max 60 seconds) for system process `vnlru' to stop...done
joeschmuck
Old Man
So this does not make sense. Why are your drives looking like they are corrupt? They should look at least only as bad as the first posting but they appear to have gotten worse. Did you do something with the drives like plug them into some other operating system? I'm a bit confused but my initial thought was that all your data was lost and now I'm almost 100% possitive its gone. You should consider running badblocks on your hard drives (Warning - Destructive) and rebuilding your pool and lastly to restore your backups.
Wish I could be of more help but if the GPT tables are hosed up...
Okay, last ditch effort if you don't have a backup copy... Run the UBUNTU Live CD and try to mount the pool. Ubuntu also has ZFS in it and you might have a Hail Mary here. You will need to do a few searches on how to mount a ZFS pool in Ubuntu but if there is a will, they you should be able to do it. If youare able to recover from this, I'd appreciate hearing about it.
aymen
Did you do something with the drives like plug them into some other operating system? no , but when the system dead (9.3) I make the new system with new install of 9.10 but I think must load back the (9.3) . thats all
thank you joeschmuck I will try ubuntu
SweetAndLow
Sweet'NASty
all disk ok !
what to do ? :(
Disk 1
Disk 2
Disk 3
Disk 4
Disk 5
These read and seek error rates make me think the disks are dead. Plus there was no smart tests executed on them except for the ones run in this thread.
Heracles
Hi aymen,
What happened during these 3 years ? What did you do with the drives ? With the system ? After 3 years sitting on a tablet, many hard drive will freeze in position and will not spin anymore...
From what you posted and people already told you, it looks like you lost 2 drives from a single RaidZ1 vDev. A pool is not meant to survive such a loss. Considering that you survived 3 years without that pool, you probably can now accept its loss and go with whatever you have now, learning in the process how fragile RaidZ1 is and how critical backups are.
joeschmuck
Old Man
Wow, it's been a long time since this thread was written to. @aymen we just assumed you fixed your problem since the thread basically died after our last responses. If you still are having a problem, you might want to start all over, explain what the system hardware is, the version of FreeNAS, and exactly any problems you are having. I'd also ensure you run some burn-in testing to ensure the system is stable. Best of luck to you.
