SOLVED Monitor Dataset Size
rolfrolf
Hello Guys,
is there a way to monitor the size of a dataset and get an E-Mail when a dataset is around 80% full?
In TrueNAS i can limit the datasets capacity but i need something like a E-Mail notification when it hits 80% capacity because i dont always check the Webinterface.
In TrueCommand i can see the stats of a specific pool but not for datasets.
Thanks in Advance.
Redcoat
How about this alert setting?
rolfrolf
Yes its set to defaults on my TrueNAS.
But i dont recieve E-Mails when a dataset it hits 80%.
The E-Mail Configuration is right because i recieve the testmails.
Redcoat
rolfrolf
I found the error.
Our Mailserver somehow marked the nofification mails as spam and deleted them instantly. Only the Testmails were forwarded.
Now it all works.
Well thank you for your time sir and have a good day.
Redcoat
I found the error.
Now it all works.
Glad it’s working for you now. You have a good day also.
