Module installation error for Unifi controller
jawakharlal
Installed TrueNAS-13.0-U6.1, created a storage intended for storing Jail.
I'm now trying to install the plugin for unificontroller, but I get the error: Error: 13.1-RELEASE not found!
I tried to run the command in the ssh console:
pkg install unifi7
and I get the error:
Updating FreeBSD repository catalogue...
FreeBSD repository is up to date.
Updating local repository catalogue...
pkg: file:///usr/ports/packages/meta.txz: No such file or directory
repository local has no meta file, using default settings
pkg: file:///usr/ports/packages/packagesite.pkg: No such file or directory
pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory
Unable to update repository local
Error updating repositories!
is it possible to do something about this?
Make yourself a new jail. (13.2-RELEASE is the right version)
run pkg install unifi8 in that jail.
jawakharlal
I still get the error:
root@truenas[~]# pkg install unifi8
root@truenas[~]#
You're at the TrueNAS console... not in the jail. That's an expected result when executed on the TrueNAS host.
iocage console <unifi jail name>
Then
pkg install unifi8
jawakharlal
and now I’m faced with the fact that I don’t know how to open the controller’s web panel.
I have a hyper-v server (192.168.111.241), it has a truenas virtual machine (192.168.111.236), it has a jail for unifi (172.16.10.30)
Which link to open the web panel?
Without commenting in detail on the lack of wisdom of your setup (hyper-v is really not supported/known to not work well), you could solve that either of 2 ways...
Since it seems you've got a NAT jail, use the host (TrueNAS) IP with the port of the service in the jail (8443 for unifi, I think).
Or you could switch to a VNET jail, which will have its own IP address... then connecting to the jail IP (still on 8443).
