Mobo Issues
nims076
I have the Jetway JNF81-T56N-LF AMD Brazos Ontario 1.6GHz Dual Core mini-ITX Mainboard
and i am trying to install the 64bit v8 Freenas on there.
After selecting option 1 for default, the installation keeps freezing at the below point:
SMP: AP CPU #1 Launched!
ugen1.1: <ATI> at usbus1
ugen0.1: <ATI> at usbus0
Any suggestions please as I cannot get past this point.
Has anyone tried this board before? If i cant get it working; can anyone suggest a decent working E-350 mobo with 6 SATA ports.
Thanks
nims076
Are you installing on a HDD? If yes, disable USB in the BIOS and try it again.
I am installing onto a USB. I did try on a HDD as well and did try what you sugeested but neither works
I noticed the ASUS has E350 and people seem to be ok installing onto there so it shouldnt be the CPU
survive
Behold the Wumpus
Hi nims076,
Be sure you are plugged into a USB2 port, not one of the (blue?) USB3 ports.
-Will
nims076
Hi nims076,
-Will
I did try that. The USB3 ports are at the front of the case and I have been using all the USB2 located at the rear. Is it the mobo? Is it the CPU? Since the ASUS with E350 works, I assumed this should as well.
