Just upgraded to RC2 and ran into trouble during the process and it's seems I'm missing my ISCI extents... I was on the prior 8.X release so I couldn't upgrade via the GUI. I tried the CD method, but CD wouldn't boot and after burning and after trying the 3rd CD incase there was a burning error of some kind... I was a little tired and just blew the full install image onto my flash drive.
When I booted with the new image and auto imported the ZFS pool, my iSCSI extents/targets/etc. seem to be missing...
Yes, I forgot to save my config via the GUI... or more to the point, I was sure I had saved it, but for some reason... don't see it... so must have screwed that up...
I have not done anything with the pool other that a zpool clear command at the console to clear an lingering error. I'd like to get a shot at the data that was one that extent as it was only there...
Also I noted that the auto-import doesn't seem to include my hot spare drive for some reason...
UPDATE: Looks like I did export the config after all so I'm not as dense as I feared. However, when the db reloaded I've run into new challenges... For one thing I had to rename some things because apparently uppercase character are no longer supported and the error message doesn't help with that... (specifically target names)
I was doing my extents as files and they have shown up at last. (they weren't visible for some period of time).. or at least the GUI couldn't find them... so now, while I'm better, I'm still in trouble... I'm trying to setup the "Associated Target" and nothing is showing up in the drop down for the extent, just a line of dashes... if I type in the extent, it says it's not valid..
Oh... FYI - This was an 8x2TB zpool setup as 7 drives in RAIDz2 and a hot spare...
UPDATE 2: Well I got it to work eventually (I don't really think I did anything as much as it finally scrubbed itself to a working point) BUT... The iSCSI Target now looks like an uninitialized disk to Windows instead of the 4TB of media that was there before. I has stayed far away from allowing Windows to do anything other than connect to the Target to confirm that that portion of the system was working...
Now about the data... any idea on how to recover it? Windows sees the target as a plain unallocated disk...
I'd appreciate any help...
