Morning everyone. I am a newbie to TrueNAS and am having an issue.
1. I have a Lenovo M-900to which I added a 2TB SSD M.s drive, a 2 TB HDD and 32 GB ram and installed TrueNAS Core 13. All of that was perfect. I also changed IP's to a static and everything is good to go. Nothing has been touched to the default install at this time. I also have a 5 drive ORICO JBOD bot populated with 1 8TB and 3 4TB drives. The 8TB is in the top slot ( might be important. )
2. Under Disks, I am seeing the HDD and the SSD but only the 8TB drive from the JBOD box.
3. during boot, the hardware sees the JBOD drives, and as TrueNAS is booting, it appears to be reading the others, but they will not show up in the Disks area.
Ok, I want to know, what commands on the cli can I use with the TrueNAS OS? I have tried all the linux ones I know and haven't found anything on the inter webs.
Also, will TrueNAS even work with a JBOD device?
Thank you in advance for any assistance.
John
John
