This is a Do I have to reinstall? question
I'm using two SSDs a Samsung 830 120GB and a OCZ Vertex 3
I've installed on the Samsung and it's running fine
I went to attach the OCZ to the boot pool to mirror and I've now found that the Samsung is showing as 119 Gb and the OCZ as 111 GB
There's shed loads of space there (6% in use) but it won't mirror over as the samsung > ocz size wise.
As the recommendation is to now use SSDs and the size of even a cheap SSD (can you buy less than 60GB drive?) means that the drives aren't anywhere near full. I can understand the issue when you had 8GB or 16GB USB sticks but ~120GB SSDs @ 6% full?
What are my options?
- Reinstall on the OCZ and add the Samsung
- Swap in a another SSD and hope it's 119 or Bigger?
- Anyway to do this via the command line
