I installed Minio plugin successfully, but I not found any correct instruction, how to configure it to work with SSL.
I have Sectigo SSL certificate, private.key and public.crt are extracted.
Can anybody give me 100% working instruction (step-by-step please, I'm not Linux guy), where to copy cert files and where is the config file, how can force Minio plugin to run with ssl.
The standard built-in S3 installation works with GUI selected SSL, but Jail Minio plugin works w/o ssl only, on standard port 9000.
TrueNAS Core, 12.0-U6, Jail release: 12.2-RELEASE-p10, Minio version: 2021.09.03.03.56.13
Thank you in advance,
Tibor
Tibor
