Min protocol not allowed in SMB share options
gamebrigada
Hey guys,
In TrueNAS 12.0-U5.1, when I try to add min protocol to Auxiliary Parameters to a share, I get this error. Current version of Samba still seems to support it. I need to set min protocol to NT1 and definitely don't want to do that system wide. This worked fine in all versions of FreeNAS 11.
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 138, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1205, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 673, in update
rv = await super().update(app, id, data)
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 495, in update
rv = await self.middleware._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb.py", line 960, in do_update
await self.middleware.call('sharing.smb.apply_conf_diff',
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1248, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/registry.py", line 227, in apply_conf_diff
return await self.apply_conf_registry(share, confdiff)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/registry.py", line 208, in apply_conf_registry
await self.reg_setparm(share, k, v)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/registry.py", line 106, in reg_setparm
return await self.netconf(action='setparm', share=share, args=[parm, value])
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/smb_/registry.py", line 61, in netconf
raise CallError(
middlewared.service_exception.CallError: [EFAULT] net conf setparm [scan] failed with error: Global parameter 'server min protocol' not allowed in service definition ('test').
anodos
Sambassador
This is actually an error being passed up from libsmbconf (from Samba). `server min protocol` is a global parameter and may not be set in a share.
gamebrigada
Hmm, that's odd that it worked fine in previous versions and the current version man page leads me to believe it should still work. We did use "min protocol", the specific error used "server min protocol" which should be equivalent.
anodos
Sambassador
<samba:parameter name="server max protocol"
                 context="G"
                 type="enum"
                 enumlist="enum_protocol"
                 xmlns:samba="http://www.samba.org/samba/DTD/samba-doc">
context="G" means that it's global-only.
