Junicast
 - Mar 6, 2015
Hallo everybody
I've been running this hardware setup for several years now:
* Intel i5 3470s 2.9 - 3.6 GHZ with 4 Cores without HT and a TDP of 65W
* Gigabyte P67A-UD3-B3
* 32 GB RAM non ECC DDR3
* PCIe Intel Gigabit Card
* 5 x 4 TB HDD (spinning disks) as RAIDZ2 encrypted
* 1 x SanDisk Cruzer Blade flash drive for OS
* 1 x 100 GB SATA SSD for L2ARC and zil (partitioned)
* 1 x USB3 4 TB external HDD for backup purposes
I plan to migrate to new hardware in order to achieve this:
* Better CPU with same TDP
* ECC instead of non ECC
* more RAM
* more space for HDD
* faster IO
That's what I plan to migrate to:
* AMD Ryzen 3600 6 Cores with HD and TDP of 65W
* Asrock Taichi X470 (those X570 need too much power)
* 64 GB ECC DDR4
* keep PCIe Intel Gigabit Card for ez migration
* keep 5 x 4 TB HDD and some day migrate to 6 x 8 TB RaidZ2
* USB Flash drive for OS, haven't decided which one (USB3?)
* 1 x Samsung Evo 970 M.2 for zil (to boost write performance)
* No more SSD read cache as my RAM should suffice for that
* keep USB3 4 TB for backup
I plan to make a configuration backup and do a fresh install onto a new flash drive and restore. If you guys are interested in the outcome I will post my results and experiences with this new hardware. Some day I might migrate to 10G Ethernet because 1G is a bit too slow for this monster setup, right?
I appreciate any thoughts on my plans. If there's no showstopper I will order the hardware next week
* more RAM
* faster IO
* 64 GB ECC DDR4
