Migrating volumes via replication
elangley
Hello All,
Running: FreeNAS-9.3-STABLE-201602031011
A volume (/data) has been migrated to a different FreeNAS installation using Replication. The volume exists and there is one snapshot.
Now I want to use (/data) as a production volume. I am deleting the replication job.
How can the snapshot be deleted yet retain the volume for use as live data permanently?
TIA,
~eric
PhilipS
I'm not sure if I am following, but you should be able to delete the snapshot from the web interface in storage, snapshots.
To be able to write to a replicated dataset, you will need to turn off the readonly attribute on the dataset from the shell:
zfs set readonly=off data
elangley
Thanks Phil,
I deleted the replication job and even though I did not change 'zfs set readonly=off' writes are possible to the replicated volume with no issues.
Was also able to delete the replicated snapshots with no issue.
~eric
PhilipS
FWIW, If you create the replication target dataset prior to setting up a replication task, then the dataset will not be set readonly=on (it would be set to inherit). The issue with doing this in a normal scenario is that someone can write data to the target and then have it wiped out by a subsequent replication and lose that data.
elangley
Not sure how that would work. You simply tell the PUSH system which dataset to replicate to. I created a dataset named 'remote' that was writable since there is no way to set readonly in the GUI.
Is there a way to view what the current 'readonly=' setting is for a volume.
Thanks, I am aware of the overwrite issue with replicated data as the most recent snapshot becomes the volume data.
~e
PhilipS
If the dataset specified in "Remote ZFS Volume/Dataset" does not exist on the remote side, the replication script will create it. When it does it will create it with the readonly attribute set to "on". Since you created a dataset on the remote, the script saw that it was already present and used it.
Not sure why they don't allow to set readonly through the GUI - maybe a feature request should be put in for this to be added to the dataset options in advanced mode. Edit: Feature request https://bugs.pcbsd.org/issues/22304
There is a column in storage, volumes that shows the readonly attribute (at least there is in 9.10.2) or from the shell: zfs get readonly <dataset>
PhilipS
