elangley
- Jun 4, 2012
Hello All,
I have a planned failover to a replica scheduled and I would like some input on the process, advantages/disadvantages and other thoughts. The failover will be temporary and failback employed.
System info:
Two FreeNAS servers both running 11.1-U7 in the same local area network.
System A replicates to System B
I want to use the System B replica to run production data.
Failover Options
It seems there are two options to do this. In both cases replication from the System A would be disabled prior to implementing.
Option A: clone the most recent replica snapshot and then mount the cloned snapshot for production use.
Option B: change the replicated dataset from read only to writable and mount the volume for production use.
Option C: ?
Failback Options - Copying the data back to System A from System is is not an option as it takes too long.
Option A: Create a replication job from Sytem B to System A.
Once the replication is completed it seems that the options are the same as when failing over, cloning or making the dataset writable. It seems that making the dataset writable would be cleaner because the other snapshots could be deleted and the dataset could be promoted.
Optin B: Not sure there is an Option B...
Let me know your thoughts and if you have done something like this.
~eric
System info:
Failover Options
Option C: ?
~eric
