Hello fine folks of Freenas forums,
I have a question regarding an upgrade I am about to perform on my server.
I purchased a Supermicro 24 bay server, following the sage advice that cyberjock wrote in a post on choosing hardware for Freenas. It was the final piece of the puzzle. I am upgrading from a Norco 4220, which in all fairness has been good so far, except that the lowest two rows of the backplane are shot or not working at all. That said, I am not going to wait for something to happen to my data. I have too many pictures, backups, documents, movies, music that I cannot risk losing anymore.
So I bit the bullet and purchased this (seemingly enterprise-grade server)
It cost $685 with shipping, so yes, I am shaking and quivering. This is it though.
The specifications for the newish server are as follows:
Server Chassis/ Case. SuperChassis ---> 846TQ-R1200B
Back Plane ---> SAS-846TQ (4UDirect Attached Backplane Supports 24x3.5\" SAS/SATA HDD/SSD )
Motherboard ---> Supermicro X8DTN+
CPU Processor ---> Dual Intel Hex Cores E5645 2.4Ghhz CPU
RAM Memory ---> 128GB DDR3 ECC REG Memory (16 x 8GB)
Comes with 24 3.5" Caddies
RAID Controller ---> None
NIC Ports ---> On board Intel® 82576 Dual-Port Gigabit Ethernet Controller
IPMI Management ---> Supports for Intelligent Platform Management Interface v.2.0
IPMI remote management upgrade card SIMPL-3+ Dedicated IPMI 2.0 included
Power Supply ---> Dual 1200Watt power supply Gold
RAILS ---> Come with Inner and Outer Rail Kit
PCI-Expansions slots --->2 (x8) PCI-E 2.0 (1 in x16 slot), 1 (x4) PCI-E (in x 8 slot)
Anyway, my question:
What approach should I take to perform the migration?
Freenas 9.10.1 is installed on a USB stick. I used 2x IBM M105 flashed to LSI firmware, which I hope to re-use in the new server.
Can I just move my HDDs to the new server, move my HBAs and stick in my USB, and call it a day?
I am thinking that since it is new hardware, specifically, a new motherboard, new processors, new network interfaces, there will some finagling to do in software. But is there ~ANY~ risk associated with data, if I go down this upgrade path?
Any advice is appreciated.
Thank you for reading!
