MiddlewareError: Failed to download <plugin>: [Errno 28] No space left on device
rathijit
Hi folks,
My FreeNAS 11.1-U2 flash boot drive stopped working, so I swapped in a new one, installed a newer build (11.1-U5) and restored the configuration though the WebGUI. Most of the settings appear to have migrated over, but I am having some trouble getting the plugins to work. The old jails (from before the migration) still exist, but FreeNAS isn't displaying them in the WebGUI. I tried to re-install the plugins, but it gives me the "No space left on device" error message. I'm not sure which device is so full that it cannot even download a few megabyte plugin. I'm not even sure why there are so many .system mounts in my system. I set the system dataset to be on the "europa" mount point.
I'm a novice at administering a FreeNAS server, but I can get by with basic *nix commands. Can someone help me get the old plugins back "online"? Here's my "zfs list" output:
root@Jupiter:~ # zfs list
NAME USED AVAIL REFER MOUNTPOINT
europa 253G 198G 176K /mnt/europa
europa/.system 38.8M 198G 192K legacy
europa/.system/configs-54a371085d1e45fe939ad239dfde9a36 22.0M 198G 21.5M legacy
europa/.system/cores 12.7M 198G 11.7M legacy
europa/.system/rrd-54a371085d1e45fe939ad239dfde9a36 288K 198G 176K legacy
europa/.system/samba4 2.83M 198G 1.28M legacy
europa/.system/syslog-54a371085d1e45fe939ad239dfde9a36 288K 198G 176K legacy
europa/VM_Linux_Mint 112G 300G 10.3G -
europa/VM_Windows_10 49.3G 198G 38.4G /mnt/europa/VM_Windows_10
europa/jails 51.5G 198G 14.2M /mnt/europa/jails
europa/jails/.warden-template-pluginjail-11.0-x64 432K 198G 3.87M /mnt/europa/jails/.warden-template-pluginjail-11.0-x64
europa/jails/.warden-template-pluginjail-11.0-x64-20180309224737 3.87M 198G 3.87M /mnt/europa/jails/.warden-template-pluginjail-11.0-x64-20180309224737
europa/jails/couchpotato_1 537M 198G 1.13G /mnt/europa/jails/couchpotato_1
europa/jails/plexmediaserver_1 49.2G 198G 49.8G /mnt/europa/jails/plexmediaserver_1
europa/jails/resilio_1 275M 198G 908M /mnt/europa/jails/resilio_1
europa/jails/sabnzbd_1 338M 198G 988M /mnt/europa/jails/sabnzbd_1
europa/jails/sickrage_1 1.09G 198G 1.06G /mnt/europa/jails/sickrage_1
europa/scratch 40.3G 198G 272K /mnt/europa/scratch
freenas-boot 859M 6.12G 64K none
freenas-boot/ROOT 850M 6.12G 29K none
freenas-boot/ROOT/Initial-Install 1K 6.12G 837M legacy
freenas-boot/ROOT/Wizard-2018-08-07_19:05:05 1K 6.12G 837M legacy
freenas-boot/ROOT/default 850M 6.12G 842M legacy
freenas-boot/grub 6.97M 6.12G 6.97M legacy
ganymede 5.18T 90.5G 88K /mnt/ganymede
ganymede/.system 576K 90.5G 96K /mnt/ganymede/.system
ganymede/.system/configs-c0708eef149b49a396f66530a6f1b80a 88K 90.5G 88K /mnt/ganymede/.system/configs-c0708eef149b49a396f66530a6f1b80a
ganymede/.system/cores 88K 90.5G 88K /mnt/ganymede/.system/cores
ganymede/.system/rrd-c0708eef149b49a396f66530a6f1b80a 88K 90.5G 88K /mnt/ganymede/.system/rrd-c0708eef149b49a396f66530a6f1b80a
ganymede/.system/samba4 128K 90.5G 128K /mnt/ganymede/.system/samba4
ganymede/.system/syslog-c0708eef149b49a396f66530a6f1b80a 88K 90.5G 88K /mnt/ganymede/.system/syslog-c0708eef149b49a396f66530a6f1b80a
ganymede/archive 5.18T 90.5G 5.18T /mnt/ganymede/archive
jupiter 6.56T 8.42T 205K /mnt/jupiter
jupiter/.bhyve_containers 188K 8.42T 188K /mnt/jupiter/.bhyve_containers
jupiter/backup 69.9G 8.42T 69.9G /mnt/jupiter/backup
jupiter/megha 59.6G 8.42T 59.5G /mnt/jupiter/megha
jupiter/rathijit 622G 8.42T 616G /mnt/jupiter/rathijit
jupiter/shared 73.5G 8.42T 73.5G /mnt/jupiter/shared
jupiter/timemachine 272G 8.42T 241G /mnt/jupiter/timemachine
jupiter/videos 5.49T 8.42T 5.48T /mnt/jupiter/videos
Thanks,
-Rathi.
D
dlavigne
Guest
Is the Jails Configuration pointing to the correct dataset?
rathijit
It wasn't pointing to the right dataset initially (right after restoring the settings), but I manually set it and it looked like it overwrote the older settings. Doesn't it merge the settings if I migrate to a different mount point?
