elvisimprsntr
- Jun 2, 2019
BACKGROUND
Even though I did not fall victim to Qlocker ransomware, I migrated my QNAP TS-253A to TrueNAS CORE.
I have almost everything working (pools, SMB/TM shares, rsync, UPS slave, etc.)
Since the TS-253A does not have dedicated SATA slots for SSDs, I installed TrueNAS CORE on a Crucial X8 500 GB USB 3 SSD, basically a M.2 SSD in a USB 3 enclosure. I figured it would be slightly better than using a thumb drive.
ISSUE
It appears that either TrueNAS does not support S.M.A.R.T. monitoring of the X8 or Crucial uses a proprietary protocol.
www.crucial.com
There is both a GUI and CLI version of Crucial Storage Executive that runs on Linux, but not sure how to get it to run under TrueNAS.
Both the GUI and CLI are .RUN files. (Note: You have to register to download)
Storage Executive GUI
Storage Executive CLI
I downloaded and changed the file to execute permission, but it did not run.
QUESTIONS
ISSUE
SMART and SSDs
Find out more about how the SMART system works to provide you with information about your SSD's health. Crucial can help.
root@NAS-2[~]# smartctl -a /dev/da1 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org /dev/da1: Unknown USB bridge [0x0634:0x5600 (0x100)] Please specify device type with the -d option. Use smartctl -h to get a usage summary
root@NAS-2[/mnt/data/alec/Software/micron]# ./StorageExecutive_Linux.run ELF binary type "3" not known. zsh: exec format error: ./StorageExecutive_Linux.run root@NAS-2[/mnt/data/alec/Software/micron]# ./msecli_Linux.run ELF binary type "3" not known. zsh: exec format error: ./msecli_Linux.run
QUESTIONS
- Is there a smartctl -d option that I need to specify specifically for the Micron USB 3 SSD with the Micron USB bridge?
- Is there a way to install/run or in any way use the linux software to monitor Micron SSDs under CORE?
- Would there perhaps be native support under SCALE?
- Or should I consider picking up a different USB 3 SSD or mechanical HD that supports native S.M.A.R.T. monitoring.
- I have a Segate 4 TB USB 3 mechanical HD that supports S.M.A.R.T natively in CORE.
root@NAS-2[/]# smartctl -i /dev/da2 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p6 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 2.5 5400 Device Model: ST4000LM024-2AN17V Serial Number: WCK0L8B1 LU WWN Device Id: 5 000c50 0a91744e6 Firmware Version: 0001 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5526 rpm Form Factor: 2.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue May 11 07:48:03 2021 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled
