EletroLaix
- Jun 29, 2017
Ciao a tutti ragazzi, FreeNAS mi ha segnalato un HDD con qualche settore danneggiato, ho stampato lo SMART e questi sono i risultati ma non ho abbastanza esperienza per valutare se la situazione è grave o no, voi che mi dite ? l'HDD è inserito in un VDEV RAIDZ da 3 dischi uguali e l'utilizzo è casalingo.
Ringrazio in anticipo.
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p5 amd64] (local build) Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 3.5 Device Model: ST3000DM008-2DM166 Serial Number: Z504K972 LU WWN Device Id: 5 000c50 0a277d75f Firmware Version: CC26 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sat Feb 1 18:41:14 2020 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM feature is: Disabled Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, frozen [SEC2] Wt Cache Reorder: Unavailable === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 37) The self-test routine was interrupted by the host with a hard or soft reset. Total time to complete Offline data collection: ( 89) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 319) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x1085) SCT Status supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-- 102 086 006 - 4438984 3 Spin_Up_Time PO---- 095 094 000 - 0 4 Start_Stop_Count -O--CK 085 085 020 - 16125 5 Reallocated_Sector_Ct PO--CK 090 090 010 - 13432 7 Seek_Error_Rate POSR-- 053 050 030 - 3827014948151 9 Power_On_Hours -O--CK 076 076 000 - 21312 10 Spin_Retry_Count PO--C- 100 100 097 - 0 12 Power_Cycle_Count -O--CK 100 100 020 - 140 183 Runtime_Bad_Block -O--CK 100 100 000 - 0 184 End-to-End_Error -O--CK 100 100 099 - 0 187 Reported_Uncorrect -O--CK 001 001 000 - 1727 188 Command_Timeout -O--CK 099 099 000 - 4 9 11 189 High_Fly_Writes -O-RCK 095 095 000 - 5 190 Airflow_Temperature_Cel -O---K 063 048 045 - 37 (Min/Max 19/41) 191 G-Sense_Error_Rate -O--CK 100 100 000 - 0 192 Power-Off_Retract_Count -O--CK 100 100 000 - 9 193 Load_Cycle_Count -O--CK 054 054 000 - 93490 194 Temperature_Celsius -O---K 037 052 000 - 37 (0 18 0 0 0) 197 Current_Pending_Sector -O--C- 096 056 000 - 776 198 Offline_Uncorrectable ----C- 096 056 000 - 776 199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0 240 Head_Flying_Hours ------ 100 253 000 - 21027h+53m+40.050s 241 Total_LBAs_Written ------ 100 253 000 - 25871943830 242 Total_LBAs_Read ------ 100 253 000 - 351676864826 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 5 Ext. Comprehensive SMART error log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x21 GPL R/O 1 Write stream error log 0x22 GPL R/O 1 Read stream error log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa1 GPL,SL VS 20 Device vendor specific log 0xa2 GPL VS 4496 Device vendor specific log 0xa8 GPL,SL VS 129 Device vendor specific log 0xa9 GPL,SL VS 1 Device vendor specific log 0xab GPL VS 1 Device vendor specific log 0xb0 GPL VS 5176 Device vendor specific log 0xbe-0xbf GPL VS 65535 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL,SL VS 10 Device vendor specific log 0xc3 GPL,SL VS 8 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (5 sectors) Device Error Count: 1728 (device log contains only the most recent 20 errors) CR = Command Register FEATR = Features Register COUNT = Count (was: Sector Count) Register LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8 LH = LBA High (was: Cylinder High) Register ] LBA LM = LBA Mid (was: Cylinder Low) Register ] Register LL = LBA Low (was: Sector Number) Register ] DV = Device (was: Device/Head) Register DC = Device Control Register ER = Error register ST = Status register Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1728 [7] occurred at disk power-on lifetime: 21312 hours (888 days + 0 hours) When the command that caused the error occurred, the device was in an unknown state. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 04 -- 51 00 00 00 00 00 00 00 00 00 00 Error: ABRT Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 00 00 00 00 00 00 00 00 00 00 00 00 ff 14d+22:32:03.713 NOP [Abort queued commands] b0 00 d4 00 00 00 00 00 c2 4f 83 40 00 14d+22:31:03.695 SMART EXECUTE OFF-LINE IMMEDIATE b0 00 d0 00 01 00 00 00 c2 4f 00 40 00 14d+22:31:03.630 SMART READ DATA ec 00 00 00 01 00 00 00 00 00 00 40 00 14d+22:31:03.627 IDENTIFY DEVICE ea 00 00 00 00 00 00 00 00 00 00 40 00 14d+22:31:01.066 FLUSH CACHE EXT Error 1727 [6] occurred at disk power-on lifetime: 21299 hours (887 days + 11 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 01 4e 03 d6 48 00 00 Error: UNC at LBA = 0x14e03d648 = 5603841608 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 00 00 10 00 00 e3 28 d5 90 40 00 14d+09:06:20.249 READ FPDMA QUEUED 60 00 00 00 80 00 01 4f 38 72 f8 40 00 14d+09:06:20.249 READ FPDMA QUEUED 60 00 00 00 80 00 01 4e 03 d7 c0 40 00 14d+09:06:20.249 READ FPDMA QUEUED 60 00 00 01 00 00 01 4e 03 d6 40 40 00 14d+09:06:20.248 READ FPDMA QUEUED 2f 00 00 00 01 00 00 00 00 00 10 00 00 14d+09:06:19.803 READ LOG EXT Error 1726 [5] occurred at disk power-on lifetime: 21299 hours (887 days + 11 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 01 4e 03 d6 48 00 00 Error: WP at LBA = 0x14e03d648 = 5603841608 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 61 00 00 00 20 00 00 e3 30 dd 20 40 00 14d+09:06:16.190 WRITE FPDMA QUEUED 61 00 00 00 08 00 00 e3 30 dc e8 40 00 14d+09:06:16.190 WRITE FPDMA QUEUED 61 00 00 00 80 00 00 e3 29 a4 90 40 00 14d+09:06:16.189 WRITE FPDMA QUEUED 61 00 00 00 48 00 00 d3 76 1d 00 40 00 14d+09:06:16.189 WRITE FPDMA QUEUED 61 00 00 00 80 00 00 d3 65 3b 40 40 00 14d+09:06:16.189 WRITE FPDMA QUEUED Error 1725 [4] occurred at disk power-on lifetime: 21299 hours (887 days + 11 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 01 4e 03 d6 48 00 00 Error: WP at LBA = 0x14e03d648 = 5603841608 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 61 00 00 00 10 00 01 4f 17 42 c0 40 00 14d+09:06:12.148 WRITE FPDMA QUEUED 61 00 00 00 18 00 01 4f 17 41 20 40 00 14d+09:06:12.148 WRITE FPDMA QUEUED 61 00 00 00 08 00 01 4f 17 40 78 40 00 14d+09:06:12.147 WRITE FPDMA QUEUED 61 00 00 00 10 00 01 4d 1c 2d 90 40 00 14d+09:06:12.147 WRITE FPDMA QUEUED 61 00 00 00 10 00 01 4d 1c 28 70 40 00 14d+09:06:12.147 WRITE FPDMA QUEUED Error 1724 [3] occurred at disk power-on lifetime: 21299 hours (887 days + 11 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 01 4e 03 d6 48 00 00 Error: WP at LBA = 0x14e03d648 = 5603841608 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 61 00 00 00 08 00 00 e3 30 dc d8 40 00 14d+09:06:08.208 WRITE FPDMA QUEUED 61 00 00 00 18 00 00 d3 76 1c e8 40 00 14d+09:06:08.178 WRITE FPDMA QUEUED 61 00 00 00 08 00 00 be 0b 9a 18 40 00 14d+09:06:08.178 WRITE FPDMA QUEUED 61 00 00 00 08 00 00 be 04 ca a8 40 00 14d+09:06:08.178 WRITE FPDMA QUEUED 61 00 00 00 58 00 00 9b 50 6a 40 40 00 14d+09:06:08.178 WRITE FPDMA QUEUED Error 1723 [2] occurred at disk power-on lifetime: 21299 hours (887 days + 11 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 01 4e 03 d6 48 00 00 Error: WP at LBA = 0x14e03d648 = 5603841608 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 61 00 00 00 08 00 00 d3 76 1c c8 40 00 14d+09:06:06.723 WRITE FPDMA QUEUED 60 00 00 00 10 00 00 e3 28 d5 90 40 00 14d+09:06:05.935 READ FPDMA QUEUED 60 00 00 00 80 00 01 4f 38 72 f8 40 00 14d+09:06:04.371 READ FPDMA QUEUED 60 00 00 00 80 00 01 4e 03 d7 c0 40 00 14d+09:06:04.370 READ FPDMA QUEUED 60 00 00 01 00 00 01 4e 03 d6 40 40 00 14d+09:06:04.363 READ FPDMA QUEUED Error 1722 [1] occurred at disk power-on lifetime: 21298 hours (887 days + 10 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 01 4d bb 1e c0 00 00 Error: UNC at LBA = 0x14dbb1ec0 = 5599076032 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 00 00 80 00 01 4d f7 79 40 40 00 14d+08:57:25.730 READ FPDMA QUEUED 60 00 00 01 00 00 01 4d bb 1f a0 40 00 14d+08:57:25.730 READ FPDMA QUEUED 60 00 00 00 80 00 01 4d bb 1e a0 40 00 14d+08:57:25.729 READ FPDMA QUEUED 2f 00 00 00 01 00 00 00 00 00 10 00 00 14d+08:57:25.677 READ LOG EXT 60 00 00 00 80 00 01 4d f7 79 40 40 00 14d+08:57:22.087 READ FPDMA QUEUED Error 1721 [0] occurred at disk power-on lifetime: 21298 hours (887 days + 10 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 01 4d bb 1e c0 00 00 Error: UNC at LBA = 0x14dbb1ec0 = 5599076032 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 00 00 80 00 01 4d f7 79 40 40 00 14d+08:57:22.087 READ FPDMA QUEUED 60 00 00 01 00 00 01 4d bb 1f a0 40 00 14d+08:57:22.086 READ FPDMA QUEUED 60 00 00 00 80 00 01 4d bb 1e a0 40 00 14d+08:57:22.086 READ FPDMA QUEUED 2f 00 00 00 01 00 00 00 00 00 10 00 00 14d+08:57:21.768 READ LOG EXT 61 00 00 00 08 00 01 4f 15 37 f8 40 00 14d+08:57:18.175 WRITE FPDMA QUEUED SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Conveyance captive Interrupted (host reset) 50% 21312 - # 2 Short captive Completed without error 00% 21312 - # 3 Short captive Completed without error 00% 21312 - # 4 Extended offline Completed: read failure 40% 21298 4138376136 # 5 Extended offline Completed: read failure 90% 20675 5541483648 # 6 Extended offline Aborted by host 90% 19967 - # 7 Extended offline Completed: read failure 90% 19247 5603413784 # 8 Extended offline Completed: read failure 10% 18518 5434601056 # 9 Extended offline Completed: read failure 10% 17853 5457535128 #10 Short offline Completed without error 00% 17833 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 522 (0x020a) Device State: Active (0) Current Temperature: 37 Celsius Power Cycle Min/Max Temperature: 18/41 Celsius Lifetime Min/Max Temperature: 17/52 Celsius Under/Over Temperature Limit Count: 0/0 SCT Data Table command not supported SCT Error Recovery Control command not supported Device Statistics (GP/SMART Log 0x04) not supported Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x000a 2 15 Device-to-host register FISes sent due to a COMRESET 0x0001 2 0 Command failed due to ICRC error 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS
