tseeling
- Oct 13, 2013
I think I have messed up a so-far working 2-disk raid1, and before proceeding I'd like to ask for advice. I'd rather try to repair for educational reasons than start from scratch and do a restore then.
I had a freenas 9.1.1 setup with 2 WD SATA disks, suddenly ada1 had lots of parity errors and was unavailable; smart reported there's a firmware upgrade available for this particular device type ("drive not accessible after powerup"). I don't think there's a coincidence but before buying a new HD I wanted to try if the FW upgrade helps with the other problem.
I attached the disk to another PC, created a boot CD from WD's iso image, upgraded the firmware, formatted with NTFS, made a full disk check, and moved it back to the freenas server.
The raid volume showed something strange instead of the /dev/xxx output I expected so I detached and removed the drive with zfs commands, with gpart deleted all partitions, destroyed the GPT and planned to re-add it as if it was a completely new device.
But whatever I try, neither CLI nor GUI, it's not possible to add the 2nd HD to the raid device ;(
I completely admit detaching was obviously some stupid action, so before I do any more damage I'd like to ask for advice on how to properly add a 2nd device to my degraded raid1. I thought I could simply "attach" a new device but it asks for a device-old and device-new although I don't have a device-old any more.
Thanks in advance ;)
