So been having an issue on SCALE for a while where I would get random issues where apps would end or the web UI would go down. After some investigation today I've noticed in my logs that due to being 'out of memory' the system is killing processes to free up more (admittedly I only have a measly 16gb of RAM but don't have that much running as just a small home server primarily used for plex streaming - need to see if there's a memory leak causing excessive usage but for now I'm just going to install more RAM).
I've noticed that the reason I cannot get back into the Web UI sometimes when this happens (temp fix is SSH in and restart middlewared and nginx service) is that the 'out of memory' handler is repeatedly killing middlewared - is this desired behaviour?
