achmetinternet
 - Jun 13, 2018
I added a user to my calibre server so that my library cannot be accessed freely by anyone in the network but only with username and password. However, after a while it seems that the login vanishes and I can just access via the adress:IP pair. Anybody run into this as well?
And funny enough I cannot just run calibre-server --enable-auth /mnt/media/eBooks I first have to onestop calibre and then I can run the command which gives me the following error Failed to start plugin: BonJour but I can then again only access via the user login data. After a while though the above happens again, no login required. I am at a loss here...
EDIT: since this is marked as solved, I will create a new post.
