Register for the iXsystems Community to get an ad-free experience
LSI 9300-8i correct config? Trying to debug system crashes
daemonix
Ive got a couple of system crashes that left no logs or kernel messages :S so Im trying to see what it might be.
Im using a LSI 9300-8i with 6 SSDs.
a) Do I need to do any BIOS updates or it seems ok to you?
root@truenas[~]# sas3flash -list Avago Technologies SAS3 Flash Utility Version 16.00.00.00 (2017.05.02) Copyright 2008-2017 Avago Technologies. All rights reserved. Adapter Selected is a Avago SAS: SAS3008(C0) Controller Number : 0 Controller : SAS3008(C0) PCI Address : 00:00:10:00 SAS Address : 500605b-0-0915-a7d2 NVDATA Version (Default) : 0e.01.00.07 NVDATA Version (Persistent) : 0e.01.00.07 Firmware Product ID : 0x2221 (IT) Firmware Version : 16.00.01.00 NVDATA Vendor : LSI NVDATA Product ID : SAS9300-8i BIOS Version : 08.37.00.00 UEFI BSD Version : 18.00.00.00 FCODE Version : N/A Board Name : SAS9300-8i Board Assembly : H3-25461-02H Board Tracer Number : XW64122ED2 Finished Processing Commands Successfully. Exiting SAS3Flash.
b) On the ASUS bios (11th gen intel) the LSI card seems to be in Legacy mode (from the BIOS -> Advance menu). Is this the recommended?
c) I have a 120mm Noctua fan very very close to the LSI (half an inch / 1cm). Low RPMs but I think its ok. No?
Thanks
mav@
`mprutil show adapter` should be able to show the HBA temperature. But I'd guess that should be OK. Though I'd probably put the fan flat on top to cool both the HBA, chipset and NIC (or what do you have in the first slot).
As I see it is a desktop system, likely with non-ECC RAM. I'd recommend a good long memory test.
blanchet
Yes you need a firmware update for your LSI HBA
Firmware Version : 16.00.12.00
But I am not sure that it will fix your issue, because running a old LSI firmware does not usually crash the system: you just regularly loose disks when the system is under heavy load.
