Thank you Redcoat! I am reading through that thread to familiarize myself. I have ran through some of the troubleshooting tips that Pro stated and here are the smart results for the 6 disks in question:
root@BN-Storage[/]# smartctl -a /dev/da40
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: Hitachi
Product: HDS721010KLA33SA
Revision: 4321
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Logical block size: 512 bytes
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x50000c900000cbbc
Serial number: GTH000PAG6YG9H
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Sat May 11 17:05:44 2019 EDT
SMART support is: Enabled
Temperature Warning: Enabled
SMART Health Status: OK
Current Drive Temperature: 38 C
Drive Trip Temperature: <not available>
Manufactured in week of year
Specified cycle count over device lifetime: 0
Accumulated start-stop cycles: 55
Read defect list: asked for grown list but didn't get it
Vendor (Seagate) cache information
Blocks sent to initiator = 62
Blocks received from initiator = 0
Blocks read from cache and sent to initiator = 43
Number of read and write commands whose size <= segment size = 0
Number of read and write commands whose size > segment size = 0
Vendor (Seagate/Hitachi) factory information
number of hours powered up = 59323.07
number of minutes until next internal SMART test = 28
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 0 0.000 0
write: 0 0 0 0 0 0.000 0
Non-medium error count: 1
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Foreground long Completed - 0 - [- - -]
# 2 Foreground long Completed - 0 - [- - -]
# 3 Foreground long Completed - 0 - [- - -]
# 4 Foreground long Completed - 0 - [- - -]
# 5 Foreground long Completed - 0 - [- - -]
# 6 Foreground long Completed - 0 - [- - -]
# 7 Foreground long Completed - 0 - [- - -]
# 8 Foreground long Completed - 0 - [- - -]
# 9 Foreground long Completed - 0 - [- - -]
#10 Foreground long Completed - 0 - [- - -]
#11 Foreground long Completed - 0 - [- - -]
#12 Foreground long Completed - 0 - [- - -]
#13 Foreground long Completed - 0 - [- - -]
#14 Foreground long Completed - 0 - [- - -]
#15 Foreground long Completed - 0 - [- - -]
#16 Foreground long Completed - 0 - [- - -]
#17 Foreground long Completed - 0 - [- - -]
#18 Foreground long Completed - 0 - [- - -]
#19 Foreground long Completed - 0 - [- - -]
root@BN-Storage[/]#
root@BN-Storage[/]# smartctl -a /dev/da41
Vendor: Hitachi
Revision: 4321
Logical Unit id: 0x50000c900001c2ac
Serial number: GTH000PAG6YHAH
Device type: disk
Local Time is: Sat May 11 17:06:50 2019 EDT
Blocks sent to initiator = 63
number of hours powered up = 59323.12
number of minutes until next internal SMART test = 27
Error counter log:
SMART Self-test log
root@BN-Storage[/]#
root@BN-Storage[/]# smartctl -a /dev/da42
Vendor: Hitachi
Revision: 4321
Logical Unit id: 0x50000c9000017060
Serial number: GTH000PAGDZ1XH
Device type: disk
Local Time is: Sat May 11 17:07:24 2019 EDT
Blocks sent to initiator = 59
number of hours powered up = 59322.85
number of minutes until next internal SMART test = 26
Error counter log:
SMART Self-test log
root@BN-Storage[/]#
root@BN-Storage[/]# smartctl -a /dev/da43
Vendor: Hitachi
Product: HDT721010SLA36SA
Revision: 4321
Logical Unit id: 0x50000c9000015d04
Serial number: STF607MH3L9L2K
Device type: disk
Local Time is: Sat May 11 17:07:57 2019 EDT
Current Drive Temperature: 35 C
Blocks sent to initiator = 54
number of hours powered up = 59322.68
number of minutes until next internal SMART test = 25
Error counter log:
SMART Self-test log
Long (extended) Self Test duration: 14100 seconds [235.0 minutes]
root@BN-Storage[/]#
root@BN-Storage[/]# smartctl -a /dev/da44
Vendor: Hitachi
Revision: 4321
Logical Unit id: 0x50000c900002d274
Serial number: GTH000PAGDZ19H
Device type: disk
Local Time is: Sat May 11 17:08:27 2019 EDT
Accumulated start-stop cycles: 64
Blocks sent to initiator = 53
number of hours powered up = 59322.78
number of minutes until next internal SMART test = 24
Error counter log:
SMART Self-test log
root@BN-Storage[/]#
root@BN-Storage[/]# smartctl -a /dev/da45
Vendor: Hitachi
Product: HDT721010SLA36SM
Revision: 4321
Logical Unit id: 0x500605ba00894754
Serial number: STF607MH3GESTK
Device type: disk
Local Time is: Sat May 11 17:09:01 2019 EDT
Drive Trip Temperature: 60 C
Manufactured in week 24 of year 2008
Specified cycle count over device lifetime: 65536
Accumulated start-stop cycles: 13
Blocks sent to initiator = 0
Error counter log:
Non-medium error count: 0
No self-tests have been logged
EDIT: I did notice that disk /dev/da45 did NOT have any self test results for the SMART information. I am currently running a long test manually on this drive to obtain SMART information. Will update post when test completes.
