My configuration is
FreeNAS 8.2
2 LSI SATA host bus adapter one with 16 ports the other with 8 ports
24 hard drives organized in 6 drives of same kind/make per pool with RAIDZ2 and the pools connected together.
The drives are green Seagate and WD hard drives (mix of 2 and 3 TB disks).
I use >1000W power supply.
Today I found that one drive got detached from the system. It appears this occurred at midnight during a ZFS scrub during high I/O load.
My question is: Do you think I have
1) electrical problem with host bus adapter/cable/backplane?
2) hard drive problem?
3) firmware problem?
Because:
1) I use inexpensive NORCO 24 bay server chassis.
2) All 6 Seagate drives (including the one that got lost) have high raw read error and seek error rate but smartctl self test shows no problems with the drives.
3) The controller firmware would need to be updated if I would upgrade to FreeNAS 8.3.
My plan is:
shutdown system, check all cables, check grounding, update firmware on controllers to latest version, reboot, replace disk, resilver.
Do you have any other suggestions?
Addendum I: It turns out the drive has no problems and the SATA port does not recognize hotswap anymore which would indicate controller firmware or electrical problem.
Addendum II: I added cooling fan for LSI controllers and I rebooted the server and all appears to be working again. I have not updated firmware.
dmsg:
I removed the drive (first offline in GUI then physically) and tested it with smartctl on separate computer. It passes a long self test:
The firmware of the controller is 11 and there is version 15 available on LSI website. FreeNAS 8.3 would require firmware 13. I use FreeNAS 8.2 and do not know firmware requirement.
FreeNAS 8.2
Because:
My plan is:
dmsg:
mps1: (1:4:0) terminated ioc 804b scsi 0 state c xfer 0 mps1: (1:4:0) terminated ioc 804b scsi 0 state c xfer 0 mps1: (1:4:0) terminated ioc 804b scsi 0 state c xfer 0 mps1: (1:4:0) terminated ioc 804b scsi 0 state c xfer 0 mps1: mpssas_remove_complete on target 0x0004, IOCStatus= 0x8 (da14:mps1:0:4:0): lost device
Dec 16 00:13:08 spxarchive kernel: mps1: (1:4:0) terminated ioc 804b scsi 0 state c xfer 0 Dec 16 00:13:08 spxarchive last message repeated 3 times Dec 16 00:13:10 spxarchive kernel: mps1: mpssas_remove_complete on target 0x0004, IOCStatus= 0x8 Dec 16 00:13:10 spxarchive root: ZFS: vdev I/O failure, zpool=spxarchive path=/dev/da14p2 offset=270336 size=8192 error=6 Dec 16 00:13:10 spxarchive kernel: (da14:mps1:0:4:0): lost device Dec 16 00:13:10 spxarchive root: ZFS: vdev I/O failure, zpool=spxarchive path=/dev/da14p2 offset=1998250844160 size=8192 error=6 Dec 16 00:13:10 spxarchive root: ZFS: vdev I/O failure, zpool=spxarchive path=/dev/da14p2 offset=1998251106304 size=8192 error=6
smartctl 6.0 2012-10-10 r3643 [i686-w64-mingw32-win7(64)-sp1] (sf-6.0-1)
Copyright (C) 2002-12, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda Green (AF)
Device Model: ST2000DL003-9VT166
Serial Number: 5YD73Q1F
LU WWN Device Id: 5 000c50 044dbda53
Firmware Version: CC3C
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5900 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue Dec 18 07:05:52 2012 USMST
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/218171en
SMART support is: Enabled
AAM level is: 0 (vendor specific), recommended: 254
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 612) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 339) minutes.
Conveyance self-test routine
SCT capabilities: (0x30b7) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 173143024
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 25
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 078 060 030 Pre-fail Always - 75319330
9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 6979
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 25
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 098 000 Old_age Always - 5
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 063 062 045 Old_age Always - 37 (Min/Max 31/38)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 24
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 25
194 Temperature_Celsius 0x0022 037 040 000 Old_age Always - 37 (0 24 0 0 0)
195 Hardware_ECC_Recovered 0x001a 022 004 000 Old_age Always - 173143024
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 235570366257987
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2498685196
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 84437231
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 6974 -
# 2 Short offline Interrupted (host reset) 00% 6966 -
# 3 Short offline Completed without error 00% 6954 -
# 4 Short offline Completed without error 00% 6942 -
# 5 Short offline Completed without error 00% 6930 -
# 6 Short offline Completed without error 00% 6918 -
# 7 Short offline Completed without error 00% 6906 -
# 8 Short offline Completed without error 00% 6894 -
# 9 Short offline Completed without error 00% 6882 -
#10 Short offline Completed without error 00% 6870 -
#11 Short offline Completed without error 00% 6858 -
#12 Short offline Completed without error 00% 6846 -
#13 Short offline Completed without error 00% 6834 -
#14 Short offline Completed without error 00% 6822 -
#15 Short offline Completed without error 00% 6810 -
#16 Short offline Completed without error 00% 6798 -
#17 Short offline Completed without error 00% 6786 -
#18 Short offline Completed without error 00% 6774 -
#19 Short offline Completed without error 00% 6762 -
#20 Short offline Completed without error 00% 6750 -
#21 Short offline Completed without error 00% 6738 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay
Oct 9 13:35:19 spxarchive kernel: mps0: <LSI SAS2116> port 0xf000-0xf0ff mem 0xfeac0000-0xfeac3fff,0xfea80000-0xfeabffff irq 18 at device 0.0 on pci1 Oct 9 13:35:19 spxarchive kernel: mps0: Firmware: 11.00.00.00 Oct 9 13:35:19 spxarchive kernel: mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> Oct 9 13:35:19 spxarchive kernel: mps0: [ITHREAD] Oct 9 13:35:19 spxarchive kernel: mps1: <LSI SAS2008> port 0xe000-0xe0ff mem 0xfe9c0000-0xfe9c3fff,0xfe980000-0xfe9bffff irq 19 at device 0.0 on pci2 Oct 9 13:35:19 spxarchive kernel: mps1: Firmware: 11.00.00.00 Oct 9 13:35:19 spxarchive kernel: mps1: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> Oct 9 13:35:19 spxarchive kernel: mps1: [ITHREAD]
