Rogla
- Jan 24, 2012
Why do I get this in my kernel log:
freenas.WORKGROUP kernel log messages:
+++ /tmp/security.EcgshnBP 2012-02-08 03:01:01.000000000 +0100
+(ada0:ahcich0:0:0:0): lost device
+(ada0:ahcich0:0:0:0): removing device entry
+ada0 at ahcich0 bus 0 scbus2 target 0 lun 0
+ada0: <Corsair Force GT 1.3.3> ATA-8 SATA 3.x device
+ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
+ada0: Command Queueing enabled
+ada0: 57241MB (117231408 512 byte sectors: 16H 63S/T 16383C)
I don't understand why it is lost and then found again several times a day.
Is this normal or something wrong in my configuration?
Some info about my system:
View attachment my_camcontrol.txt
View attachment my_dmesg.txt
The ada0 SSD is the cache disk, 60 GB.
FreeNAS Build FreeNAS-8.0.3-RELEASE_MULTIMEDIA-p1-x64 (9591) (fresh install, not an upgrade)
Platform AMD A8-3870 APU with Radeon(tm) HD Graphics
Memory 15837MB
The storage volume is ada1..ada6.
This "lost device" issue make me question if I can trust the setup.
Despite this, the read and write performance on the local volume is very good:
[Roger@freenas] ~/vol0> dd if=/dev/zero of=./tmp.dat bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 97.723123 secs (1098759222 bytes/sec)
[Roger@freenas] ~/vol0> dd if=./tmp.dat of=/dev/null bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 104.558536 secs (1026928902 bytes/sec)
[Roger@freenas] ~/vol0> ls -l ./tmp.dat
-rw-r--r-- 1 Roger wheel 107374182400 Feb 7 22:01 ./tmp.dat
Memory 15837MB
51200+0 records in
51200+0 records out
51200+0 records in
51200+0 records out
