Phil Williams
- Feb 1, 2023
I've spotted an irritating behaviour when testing applications. As I hit the applications section I am promoted to select the pool. If I select the desired pool I get a window saying Kubernetes is being configured or similar and this hangs for about 30 seconds. Eventually, I lose access to the WebGui and the only resolution I have found so far is to restore from the CLI. Naturally not a long-term fix.
I have a feeling that this may be because the apps wants to use the same IP address I have assigned for the server. so my proposed plan is the following:
For context: I may use apps in the future but I want to create a docker container to hold MakeMKV so I can rip my DVDs from the NAS rather than a separate machine.
- Under System Settings > General > GUI > Settings I set the Web Interface IPv4 Address to 192.168.0.6
- Under network > Static Routes I add a new static route of 192.168.0.7
- Under Apps > Settings > Advanced Settings > Node IP I use this new IP (192.168.0.7)
- For the route v4 interface, I set this to the same NIC as the web GUI (I have four to choose from if this makes any difference)
