Lose a lot of performance when I added multiple disks
kikotte
I drive with 6 disks of mirror and got good performance every disk write 200MB per sec but when i add 6 disks to it, it only writes 60MB per disk.
dd if=/dev/zero of=tmp.dat bs=2048k count=150k
Check my signature for the hardware.
Version: FreeNAS-11.1-U1
They are in the same pool and do not do the same work, is it because the counter is working on other things?
[root@freenas ~]# zpool status
  pool: Store2
 state: ONLINE
  scan: none requested
	   NAME												STATE	 READ WRITE CKSUM
	   Store2											  ONLINE	   0	 0	 0
		 mirror-0										  ONLINE	   0	 0	 0
		   gptid/9d17bcbc-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		   gptid/9df33389-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		 mirror-1										  ONLINE	   0	 0	 0
		   gptid/a03134f9-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		   gptid/a0f17bac-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		 mirror-2										  ONLINE	   0	 0	 0
		   gptid/a3334340-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		   gptid/a3f64588-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		 mirror-4										  ONLINE	   0	 0	 0
		   gptid/5d4a0fd3-1312-11e8-b729-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		   gptid/5e12941f-1312-11e8-b729-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		 mirror-5										  ONLINE	   0	 0	 0
		   gptid/612876f0-1312-11e8-b729-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		   gptid/61eacf52-1312-11e8-b729-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		 mirror-6										  ONLINE	   0	 0	 0
		   gptid/65096079-1312-11e8-b729-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		   gptid/65d19969-1312-11e8-b729-0cc47a5808e8.eli  ONLINE	   0	 0	 0
	   logs
		 mirror-3										  ONLINE	   0	 0	 0
		   gptid/a4d713ca-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
		   gptid/a549c4e3-066b-11e8-b8a8-0cc47a5808e8.eli  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:05 with 0 errors on Thu Feb 15 03:45:05 2018
	   freenas-boot  ONLINE	   0	 0	 0
		   da12p2  ONLINE	   0	 0	 0
		   da13p2  ONLINE	   0	 0	 0
[root@freenas ~]# glabel status
									 Name  Status  Components
gptid/a4d713ca-066b-11e8-b8a8-0cc47a5808e8	 N/A  nvd0p2
gptid/a549c4e3-066b-11e8-b8a8-0cc47a5808e8	 N/A  nvd1p2
gptid/9d17bcbc-066b-11e8-b8a8-0cc47a5808e8	 N/A  da2p2
gptid/9df33389-066b-11e8-b8a8-0cc47a5808e8	 N/A  da5p2
gptid/a03134f9-066b-11e8-b8a8-0cc47a5808e8	 N/A  da8p2
gptid/a0f17bac-066b-11e8-b8a8-0cc47a5808e8	 N/A  da9p2
gptid/a3334340-066b-11e8-b8a8-0cc47a5808e8	 N/A  da10p2
gptid/a3f64588-066b-11e8-b8a8-0cc47a5808e8	 N/A  da11p2
gptid/ed20a3de-b526-11e7-bceb-002590e35b10	 N/A  da12p1
gptid/ed276c6c-b526-11e7-bceb-002590e35b10	 N/A  da13p1
gptid/5d4a0fd3-1312-11e8-b729-0cc47a5808e8	 N/A  da0p2
gptid/5e12941f-1312-11e8-b729-0cc47a5808e8	 N/A  da1p2
gptid/612876f0-1312-11e8-b729-0cc47a5808e8	 N/A  da3p2
gptid/61eacf52-1312-11e8-b729-0cc47a5808e8	 N/A  da4p2
gptid/65096079-1312-11e8-b729-0cc47a5808e8	 N/A  da6p2
gptid/65d19969-1312-11e8-b729-0cc47a5808e8	 N/A  da7p2
gptid/65becc6a-1312-11e8-b729-0cc47a5808e8	 N/A  da7p1
gptid/64f8aa3f-1312-11e8-b729-0cc47a5808e8	 N/A  da6p1
gptid/61da5155-1312-11e8-b729-0cc47a5808e8	 N/A  da4p1
gptid/6117fff7-1312-11e8-b729-0cc47a5808e8	 N/A  da3p1
garm
Please abide by the rules and post your hardware so we can see it and it’s persistent.. I have no idea what your SLOG drives are, but I’m guessing your maxing them out?
kikotte
FreeNAS1: motherboard supermicro X9DRH-7TF, CPU X2 E5-2680V1, RAM 256GB ECC, HBA card LSI 9300-16i, HDD X12 WD gold 6TB, slog/zli X2 Intel DC P3520 1.2TB, OS disks X2 Samsung SM863 120GB
Arwen
One thing ZFS tries to do, is balance the space used across all the vDevs. So, if your pre-existing 3 x 2 way Mirrored vDevs were fullish, then all new writes would be to the new vDevs almost exclusively.
Please supply the output of zpool list -v in code tags.
Note that there is no automatic balancing of existing when adding new vDevs. Data stays where it was written originally. Other RAID solutions may do this, but ZFS does not. Partly due to to certain advanced features like snapshots & clones would complicate data balancing.
tvsjr
And why are you running a pair of drives in a mirror for your SLOG? That just adds overhead.
kikotte
[root@freenas ~]# zpool list -v
NAME									 SIZE  ALLOC   FREE  EXPANDSZ   FRAG	CAP  DEDUP  HEALTH  ALTROOT
Store2								  32.6T  4.35T  28.3T		 -	 1%	13%  1.00x  ONLINE  /mnt
  mirror								5.44T  1.41T  4.02T		 -	 2%	25%
   gptid/9d17bcbc-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
   gptid/9df33389-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
  mirror								5.44T  1.45T  3.98T		 -	 2%	26%
   gptid/a03134f9-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
   gptid/a0f17bac-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
  mirror								5.44T  1.46T  3.98T		 -	 2%	26%
   gptid/a3334340-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
   gptid/a3f64588-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
  mirror								5.44T  10.2G  5.43T		 -	 0%	 0%
   gptid/5d4a0fd3-1312-11e8-b729-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
   gptid/5e12941f-1312-11e8-b729-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
  mirror								5.44T  10.9G  5.43T		 -	 0%	 0%
   gptid/612876f0-1312-11e8-b729-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
   gptid/61eacf52-1312-11e8-b729-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
  mirror								5.44T  10.7G  5.43T		 -	 0%	 0%
   gptid/65096079-1312-11e8-b729-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
   gptid/65d19969-1312-11e8-b729-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
log										 -	  -	  -		 -	  -	  -
  mirror								1.09T  39.2M  1.09T		 -	 0%	 0%
   gptid/a4d713ca-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
   gptid/a549c4e3-066b-11e8-b8a8-0cc47a5808e8.eli	  -	  -	  -		 -	  -	  -
freenas-boot							 111G  2.07G   109G		 -	  -	 1%  1.00x  ONLINE  -
  mirror								 111G  2.07G   109G		 -	  -	 1%
   da12p2								  -	  -	  -		 -	  -	  -
   da13p2								  -	  -	  -		 -	  -	  -
[root@freenas ~]#
Money is no big problem just to save a while.
garm
Han menar inte kostnaden, utan resurserna som krävs för en IO.
He doesn’t mean the cost, but the system resources needed for an IO
kikotte
Ah, blir den sämre för att man gör en mirror med slog försämra IO på det sättet?
kikotte
@Arwen
It's fine, it does not use them because there are no data there.
So the question is how to fix this? Otherwise, I can buy additional hard disks as backup disk.
Stux
It’s actually a best practice, if your transactions are very important, or if you need the system to stay performant even when a SLOG fails.
tvsjr
Eh, I suppose. That exceeds my level of paranoia.
Arwen
Please note that at a earlier time, loss of a SLOG meant not just the loss of the transactions it was saving, but the entire pool!
So, Sun Microsystems added the ability to mirror SLOGs as a way to prevent pool loss.
It was years later that someone, (I don't know if it was Sun or outsider), fixed that issue.
Arwen
@kikotte, take a look at the busy disks and how much they have stored on them. You might be able to answer your own question. (Sorry, I can't today, I have FBS - Fried Brain Syndrome...)
Stux
Stux
200MB -> 60MB/s sounds suspiciously like the slow down from an empty disk to a semi-full and fragmented disk.
kikotte
I guess I can buy two hard drives as I can move over to data and then redo the pool.
tvsjr
True... but I don't intend to jump back several years in FreeNAS versions to experience that particular pain point :)
Stux
So, as I hinted at, there are two reasons to mirror slog.
One is to deal with the rate failure case where a slog dies during a crash, Ie it disappears before the separate intent log can be rewritten to main pool, and the other reason is if loss of slog will cause a serious enough performance loss that it might as well be considered a system failure.
kikotte
Is there no one who can solve my problem?
There are only 6 disks used when there are no data on the other 6 disks how do I move data so that all 12 disks can work?
You don't. You use the pool normally and ZFS will optimize things to maximize performance.
