 - May 28, 2011
Fellow FreeNAS members, I am in search of a commercial NAS unit that meets the below listed requirements and I turn to you for some advice.  Let me preface this with that while I'd love to use a FreeNAS system here, I unfortunately cannot in the environment where it will be utilized.  This will be used for company use.  It will be on a closed network as well, no outside access at all.
Requirements:
New commercial device.
1GB NIC - Full speed bandwidth transfers over SMB.
10TB to 14TB with some sort of RAID type redundancy, similar to RAID-Z2.
Easy to replace a failing/failed hard drive (don't need a be an expert to do this operation).
Send an email to at least two people when a problem occurs, and possibly send an email daily when things are working fine.
Cost is always a factor even though it's not my money.
Use Case:
Backup full hard drive images of up to ten laptops (hence the requirement to saturate the 1Gb NIC connection).
Backup additional user data for up to ten personnel.
I would like the system to not have a lot of those small 40mm or smaller fans but I guess those could be replaced if needed.
I don't believe noise will be a factor as there is a location outside the office space where it can be locked up in a vault.
I would prefer that the device have maybe a RAID6 setup and installing Five 4TB hard drives now (~11TB) and having the expand-ability to add a Sixth 4TB drive to expand the RAID to ~14TB. I have some homework to do myself as well, I need to research from a configuration point of view what my drive configurations can be for a RAID6. I don't want to assume anything.
So for those IT Admins out there, I would really appreciate your inputs for the good devices and the ones to stay away from.
Thanks!
P.S. I would humor a 10Gb NIC connection as well.
			Requirements:
Use Case:
Thanks!
