boatymcboatface
 - Jul 11, 2016
Greetings!
I'm looking for some opinions on various hardware options for my home setup. At present I have a fairly neat kit running FreeNAS Corral:
E3-1275v5 processor
Supermicro X11SSH-LN4F board
64GB ECC memory
There are several challenges on the horizon. First of all, I can't stand something running perfectly and after a while I have to mess with it ;)
Storing the data properly is important, but I'll admit immediately that a big factor in this is just the fun of messing with it.
Secondly, I am moving house soon and will be putting new cabling, switches etc in so using that as an opportunity to jump on the 10Gbit bandwagon, something this board does not support. It has limited expansion ports, ports currently filled with M1015s.
Third, and perhaps most important - my array currently consists of 10 x 8 TB drives cut into two RAIDZ-1 Vdevs of 5 disks (along with a bunch of SSD's on the mobo ports). Being the data hoarder that I am, this is rapidly filling up.
My main concern is breaking the recommended barrier of 1GB memory per 1TB above 8GB. 64 gig is the max this setup will take, it being an E3 and all.
Mind you, this is my home setup so load is very light for a setup this large.
Now, I can sell some or all of the mobo/proc/mem combo above to a friend, who is actually looking for a setup like mine, with more modest storage requirements (read: not afflicted by obsessive/compulsive data-hoardery).
Here's a couple of thoughts:
1) Keep proc + mem, get the X11SSH-CTF.
Pros: modest upgrade, SAS3 controller onboard, 10 gig ethernet on board.
Cons: Still only 64GB memory.
2) Sell proc, mem + board and get a Xeon-D board. Xeon-D 1537 I suspect will have roughly similar performance, Xeon-D 1541 is probably a bit faster (Supermicro and ASRockRack offerings, respectively - both with SAS onboard and 10 Gbit).
Pros: SAS2/3 controller onboard. 10 Gbit onboard. Memory limit goes up to 128GB.
Cons: Full upgrade, more costly. No option to upgrade processor later (though I doubt I'd need to for a while).
3) Anything I didn't think of yet?
I looked at E5 offerings, but I find those are either very slow compared to the processors above, or prohibitively expensive. I mean none of this is small change but the price goes up dramatically if you look for an E5 with similar performance as the above it seems.
Also registered memory seems to be insanely expensive. I paid approximately 350 euros for 64 gig proper DDR4 ECC memory last year. If I look at the price of a single 32GB DDR4 Registered module, which would be needed on the Xeon-D boards to take me to 128GB, they seem to be around that price range already meaning 128GB would land in the 1300ish euros area. That's pretty damn steep.
I look forward to some suggestions or other options to consider :)
Many thanks!
BmcBF
E3-1275v5 processor
64GB ECC memory
Many thanks!
BmcBF
