chillincool
- Aug 22, 2018
TL;DR: I'm already aware that this system is more than enough for FreeNas without making a post. I'm asking a lot of questions that I don't feel necessarily contribute to the intended purpose of this community...so please ignore this whole post if you aren't OK with that.
Use case: It's just me and my wife. I'm a "computer geek" who has half-learned a bunch of stuff and want a lab environment to tinker with. FreeNAS will pretty much exclusively be used to store replaceable media data that I will just re-download in the event of catastrophe. I have a very lucrative job troubleshooting physical copper wire and fiber optics for a top-tier ISP that I'm bored to death with and want to expand my horizons while at home in the hopes that I can gain enough experience in the IT field that I might be able to skip downgrading myself to the pay and monotony of help-desk level work. My wife does construction and is becoming more and more involved in doing the computational work of using blueprints to calculate materials needed for quick and accurate price quotes.
Hardware:
Supermicro 2u chassis w/ redundant 920w platinum rated psu(somewhat set on something that's rack mountable as I already have a few other things rack mounted)
2x v2 intel e5-2630L
64gb(16x 4gb) ddr3 eec ram
2x lsi 9810-8i(it-mode)
4 intel gbit lan ports on mb - may add additional gb ports via pcie or 10gbit depending on future needs
4tb wd red x 5 for raidz - assortment of other hd as needed for other things
Here's my planned setup:
ESXI as host OS
The wife runs a company that installs pavers, french drains, etc. Would mostly be 2d stuff amounting to editing illustrating 2d things that are similar to blueprints. I know very little about this line of work and the computational requirements of it, but I'd like to give the wife the ability to remote in and draw up simple plans. I didn't plan on adding any type of deducated GPU card in this built, but depending on circumstances, I'd be willing to throw in a Quatro down the line for this...or scrap this idea completely if it isn't realistic.
Home automation
Simple stuff like light control, ac, universal remotes, etc.
My main concerns:
Utmost concern: I'm saving a TON money by going with a DD3 setup. I've been building computers for the last 15 years or so, but not frequently enough to keep track of end of life things. Is it worth the massive price increase to get a ddr4 setup purely for ease of finding replacements when performance isn't a concern? In the future, I may end up building an additional server based on my needs, but I'd like this server to last me as long as possible. I know DDR2 is so hard-to-find at this point that the price is inflated...just looking for someone with more experience to enlighten me on what to expect with DDR3.
Lesser concern: Am I expecting too much out of the 2x v2 e5-3620L's? I've separated my uses basically how I expect them to be separated as far as which VM they are on. Should some of these be combined?
I'm also open to any suggestions anyone has for me to do what I'm looking to do with less hardware...when you're skirting the line between common residential needs and enterprise, sometimes it seems that the sky is the limit as far as hardware goes and my starry-eyed geekiness sometimes takes me down an overly-expensive rabbit-hole.
I'm fully prepared to spend MONTHS fooling with this to get it working the way I want, and I wouldn't have it any other way. I really appreciate any comments, and if someone has a suggestion for a more appropriate place for me to post this, feel free.
Thanks, Chillin
Hardware:
ESXI as host OS
- Freenas - not really looking to be convinced on why this shouldn't be a VM. The appropriate hardware will be set as pass-through. I don't want to lose this data, but if I do...I'll just redownload it. This is largely just a lab and proof of concept.
- exposed to the internet
- dedicated hba
- 4tbx5 sats drives raidz for media
- will add separate datastore later on as needed
- plex plugin with the intention of 3-5 simultaneous transcodes - this will be primarily only be used by me/wife. I MAY give access to my mom after I'm satisfied with stability
- any other jails and/or docker sessions that make sense to run on this VM
- pfsense
- openvpn
- vlans with trunking
- certain vlans running through vpn, others not
- firewall
- GNS3
- running on partition connected to onboard
- several virtualized cisco appliances
- several low end/bare-bone OS installs used only for the purpose of simulating real world connectivity with PCS
- I may allow a few friends access to this to practice as well
- Linux server install
- not exposed
- 2 dedicated hd setup as a mirror, with a remote backup
- domain server to play with
- email filtering
- small database to play with
- store tax info for 1099 work
- rtorrent
- nzbget/couch potato/similar
- list of files to redownload data stored on Freenas media dataset in the event of a catastrophic failure
- Optional:
Home automation
My main concerns:
Thanks, Chillin
