oldcripple
- Oct 20, 2018
I've had this server for a couple of months and its working fine but from the beginning I've gotten the above error on all smartctl long tests.
I've tried everything I could think of, and tried some of the different options on the smartmontools wiki. All drives have this error, short tests return no errors but I'd like to at least know whats causing this if not how to fix it.
System
Edited to move specs to body for mobile users
root@MyNAS:~ # smartctl -a /dev/da0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: HITACHI
Product: HUS72302CLAR2000
Revision: C1D6
Compliance: SPC-4
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Logical block size: 512 bytes
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca01c2b6e00
Serial number: YGGSWE9D
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Mon Mar 4 01:19:30 2019 EST
SMART support is: Enabled
Temperature Warning: Disabled or Not Supported
SMART Health Status: OK
Current Drive Temperature: 29 C
Drive Trip Temperature: 85 C
Manufactured in week 10 of year 2012
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 21
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 2242
Elements in grown defect list: 0
Vendor (Seagate) cache information
Blocks sent to initiator = 2719892699955068928
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 652877 0 652877 47065833 219628.551 0
write: 0 3041096 0 3041096 220326 74384.445 0
verify: 0 6755 0 6755 201970 69394.434 0
Non-medium error count: 0
SMART Self-test log
Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ]
Description number (hours)
# 1 Background short Completed - 53278 - [- - -]
# 2 Background short Completed - 53254 - [- - -]
# 3 Background short Completed - 53186 - [- - -]
# 4 Background short Completed - 53185 - [- - -]
# 5 Background short Completed - 53017 - [- - -]
# 6 Background short Completed - 52849 - [- - -]
# 7 Background short Completed - 52681 - [- - -]
# 8 Background short Completed - 52441 - [- - -]
# 9 Background short Completed - 52283 - [- - -]
#10 Background short Completed - 52115 - [- - -]
#11 Background short Completed - 51947 - [- - -]
#12 Background short Completed - 51707 - [- - -]
#13 Background short Completed - 51539 - [- - -]
#14 Background short Completed - 51371 - [- - -]
#15 Background short Completed - 51203 - [- - -]
#16 Background short Completed - 50987 - [- - -]
#17 Background short Completed - 50789 - [- - -]
#18 Background short Completed - 50621 - [- - -]
#19 Background short Completed - 50453 - [- - -]
#20 Background short Completed - 50435 - [- - -]
Long (extended) Self Test duration: 6 seconds [0.1 minutes]Code:
root@MyNAS:~ # smartctl -r ioctl -t long /dev/da0 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org [inquiry: 12 00 00 00 24 00 ] CAM status=0x1, SCSI status=0x0, resid=0x0 status=0x0 [inquiry: 12 01 00 00 fc 00 ] CAM status=0x1, SCSI status=0x0, resid=0xeb status=0x0 [inquiry: 12 00 00 00 24 00 ] CAM status=0x1, SCSI status=0x0, resid=0x0 status=0x0 [request sense: 03 00 00 00 12 00 ] CAM status=0x1, SCSI status=0x0, resid=0x0 status=0x0 [send diagnostic: 1d 40 00 00 00 00 ] CAM status=0x8c, SCSI status=0x2, resid=0x0 sense_len=0x20, sense_resid=0x0 status=0x2: sense_key=0x5 asc=0x24 ascq=0x0 Long (extended) offline self test failed [unsupported field in scsi command]
root@MyNAS:~ # smartctl -x /dev/da0
Vendor: HITACHI
Revision: C1D6
Compliance: SPC-4
Device type: disk
Local Time is: Mon Mar 4 02:23:36 2019 EST
Read Cache is: Enabled
Writeback Cache is: Disabled
Blocks sent to initiator = 9608429804994953216
Error counter log:
read: 0 652885 0 652885 47065962 219633.978 0
write: 0 3041792 0 3041792 220355 74393.732 0
verify: 0 6755 0 6755 201973 69394.434 0
SMART Self-test log
Background scan results log
Status: waiting until BMS interval timer expires
Accumulated power on time, hours:minutes 53280:48 [3196848 minutes]
Number of background scans performed: 313, scan progress: 0.00%
Number of background medium scans performed: 313
Protocol Specific port log page for SAS SSP
relative target port id = 1
generation code = 7
number of phys = 1
phy identifier = 0
attached device type: SAS or SATA device
attached reason: power on
reason: unknown
negotiated logical link rate: phy enabled; 6 Gbps
attached initiator port: ssp=1 stp=1 smp=1
attached target port: ssp=0 stp=0 smp=0
SAS address = 0x5000cca01c2b6e01
attached SAS address = 0x500605b005f80e90
attached phy identifier = 0
Invalid DWORD count = 267
Running disparity error count = 256
Loss of DWORD synchronization = 67
Phy reset problem = 0
Phy event descriptors:
Invalid word count: 267
Running disparity error count: 256
Loss of dword synchronization count: 67
Phy reset problem count: 0
relative target port id = 2
generation code = 7
number of phys = 1
phy identifier = 1
attached device type: no device attached
attached reason: unknown
reason: power on
negotiated logical link rate: phy enabled; unknown
attached initiator port: ssp=0 stp=0 smp=0
SAS address = 0x5000cca01c2b6e02
attached SAS address = 0x0
Invalid DWORD count = 0
Running disparity error count = 0
Loss of DWORD synchronization = 0
Invalid word count: 0
Running disparity error count: 0
Loss of dword synchronization count: 0
Phy reset problem count: 0System
SuperMicro X9DRi-LN4+ 2x, Intel E5-2620 2x LSI9210-8i HBA Controllers 32GB SATADOM FreeNAS 11.2-U2 boot drive 32GB RAM (8x4GB) 12x2TB HDD (2x6HDD RAIDZ2 Pools)
