Hi I am trying to install LMS on FreeNAS with this instructions.
https://audiodigitale.eu/?p=87
I created new jail and type
after lots of installing I am stuck with error below.
Can some one please help me how to solve this. Thank you :)
portmaster audio/logitechmediaserver
===>>> Installation of shells/bash (bash-4.4.12_2) succeeded ===>>> Returning to dependency check for audio/logitechmediaserver ===>>> Dependency check complete for audio/logitechmediaserver ===> Cleaning for logitechmediaserver-7.9.0.g2016.09.30_2 make: don't know how to make pretty-flavors-package-names. Stop ===> License SDL needs confirmation, will ask later ===> logitechmediaserver-7.9.0.g2016.09.30_2 depends on file: /usr/local/sbin/pkg - found => Logitech-slimserver-7.9.0.g2016.09.30-c835a1f_GH0.tar.gz doesn't seem to exist in /usr/ports/distfiles//. => Attempting to fetch https://codeload.github.com/Logitech/slimserver/tar.gz/c835a1f?dummy=/Logitech-slimserver-7.9.0.g2016.09.30-c835a1f_GH0.tar.gz fetch: https://codeload.github.com/Logitech/slimserver/tar.gz/c835a1f?dummy=/Logitech-slimserver-7.9.0.g2016.09.30-c835a1f_GH0.tar.gz: size unknown fetch: https://codeload.github.com/Logitech/slimserver/tar.gz/c835a1f?dummy=/Logitech-slimserver-7.9.0.g2016.09.30-c835a1f_GH0.tar.gz: size of remote file is not known Logitech-slimserver-7.9.0.g2016.09.30-c835a1f_ 179 MB 7043 kBps 00m26s => Fetched file size mismatch (expected 187923230, actual 187921541) => Trying next site => Attempting to fetch http://distcache.FreeBSD.org/ports-distfiles/Logitech-slimserver-7.9.0.g2016.09.30-c835a1f_GH0.tar.gz fetch: http://distcache.FreeBSD.org/ports-distfiles/Logitech-slimserver-7.9.0.g2016.09.30-c835a1f_GH0.tar.gz: Not Found => Couldn't fetch it - please try to retrieve this => port manually into /usr/ports/distfiles// and try again. *** Error code 1 Stop. make[1]: stopped in /usr/ports/audio/logitechmediaserver *** Error code 1 Stop. make: stopped in /usr/ports/audio/logitechmediaserver ===>>> make build failed for audio/logitechmediaserver ===>>> Aborting update ===>>> There are messages from installed ports to display, but first take a moment to review the error messages above. Then press Enter when ready to proceed.
