We are using an older system for holding disk to disk backups of our SQL databases. The load is minimal. We increased RAM to 2GB, and tried to tune the vm.kmem_size, but nothing seems to work.
I have followed as many threads as I can, and I cannot see the problem.
Here is my loader.conf
Here is the relevent line from /boot/defaults/loader.conf
Here is the output from sysctl:
I just upgraded to 8.0.1-RC1. It was the only disk I had on hand and I had to reinstall because of a boot-disk failure. Can anyone give me some guidance?
# Boot loader file for FreeNAS. This relies on a hacked beastie.4th.
autoboot_delay="2"
loader_logo="freenas"
#Fix booting from USB device bug
kern.cam.boot_delay=10000
vm.kmem_size_max="1536M"
vm.kmem_size="1024M"
# GEOM support
geom_mirror_load="YES"
geom_stripe_load="YES"
geom_raid3_load="YES"
#geom_raid5_load="YES"
ntfs_load="YES"
smbfs_load="YES"
loader_conf_files="/boot/device.hints /boot/loader.conf /boot/loader.conf.local"
[joshua@backup ~]$ sysctl -a|grep kmem_size
vm.kmem_size_scale: 3
vm.kmem_size_max: 335544320
vm.kmem_size_min: 0
vm.kmem_size: 335544320
