freenas 8.0.3 freezes when transferring data with panic:vm_page_insert
Luksh
SOLVED.
Hi!
Please, help, my server freeze every hour when I transfer data to it and writes to the console:
panic: vm_page_insert: page already inserted
cpuid = 3
Uptime: 37m27s
version of freenas: 8.0.3 p1, 64-bit
motherboard: intel d525mwv
cpu: atom d525
Memory: samsung 2Gb * 2pcs
hdd: seagate hybrid st95005620as * 2pcs
loader.conf:
autoboot_delay="2"
loader_logo="freenas"
kern.cam.boot_delay=10000
vfs.zfs.prefetch_disable="0"
vfs.zfs.txg.timeout="5"
vm.kmem_size="2048M"
vfs.zfs.arc_min="256M"
vfs.zfs.arc_max="1024M"
vfs.zfs.vdev.min_pending="4"
vfs.zfs.vdev.max_pending="8"
fuse_load="YES"
geom_mirror_load="YES"
geom_stripe_load="YES"
geom_raid3_load="YES"
geom_gate_load="YES"
debug.debugger_on_panic=1
hw.hptrr.attach_generic=0
system config:
freenas ready 3.2Gb RAM
hdd in acpi mode via BIOS
zfs volume: mirror raid + force 4096 sector size
cifs share
data transfer from winxp.sp3
vm_page_insert regardless of the size of transmitted data
memcheck runs without errors
How to be?
Thanks!
Luksh
I did not understand what you mean?
You propose to try the version 8.0.3-p1-32-bit or ... ?
William Grzybowski
No.. i didnt see you wrote 64bit back there...
Try remove this kmem_size and arc values from your loader.conf
G
gcooper
Guest
I assume you're using CIFS based on the info above. What network driver are you using?
joeschmuck
Old Man
Do you have NFS enabled? If so try to disable it. I read this solved the issue for some folks but not all.
Luksh
SOLVED.
Problem was in BIOS.
flashed 0113 version 2.7.2012, and normal flight for 2 weeks.
Thanks for your help!
