Liveness probe (custom) in TrueNAS SCALE?
SD298
How do I set custom liveness probe in containers running in TrueNAS SCALE?
Thanks.
truecharts
We currently do not support this for most of our Apps (would need to check for custom-app though).
But all our Apps do include custom and solid liveness probes.
stavros-k
Currently on custom app we only have the option to either disable probes or set custom path for http based probes.
It was a quick addition, (mostly for the disable part) as there was a few custom containers that couldn't be probed and failed to start.
SD298
Can you pls tell how to set the options? I am unable find it.
Thanks in advance.
stavros-k
You have to use "custom-app" app.
If you need more help you have to visit our discord.
We don't watch forums very much.
