i try to get Adguard Home running inside a jail.
Used the docker template and only changed the systemd_nspawn_user_args
/etc/resolv.conf inside the jail
Added a static IP like described here.
My compose.yaml
I can access the web interface via 192.168.0.10, but if i set the DNS on my router to 192.168.0.10 or direct to my Mac under Network Settings, no website will be loaded.
Any idea?
systemd_nspawn_user_args=--network-macvlan=eno1 --resolv-conf=off --system-call-filter='add_key keyctl bpf' --bind='/mnt/tank/jailmaker/docker-data/adguard:/docker-data/adguard'
nameserver 127.0.0.1 search .
My compose.yaml
version: "3" services: adguardhome: image: adguard/adguardhome container_name: adguardhome deploy: resources: limits: cpus: '0.50' # max. 50% memory: 300m reservations: cpus: '0.1' memory: 100m volumes: - '/docker-data/adguard/conf:/opt/adguardhome/conf' - '/docker-data/adguard/work:/opt/adguardhome/work' ports: # DNS - 53:53/tcp - 53:53/udp # DHCP server #- 67:67/udp #- 68:68/tcp #- 68:68/udp # HTTPS/DNS-over-HTTPS #- 443:443/tcp # DNS-over-TLS - 853:853/tcp # DNS-over-QUIC #- 784:784/udp # DNSCrypt #- 5443:5443/tcp #- 5443:5443/udp # WebUI - 80:80/tcp - 443:443/tcp #- 443:443/udp # WebUI Setup - 3000:3000/tcp restart: unless-stopped
Any idea?
