Link Aggregation
Tong
Doesn't work. I have Dlink DGS-1210-24 switch. I cannot get it to LACP on both freenas and my windows server. Attached is static LAGG setup for windows server and switch.
On freenas I cannot find settings to make LAGG work. What are requirements and any suggestions? Realtek chipset.
vegaman
It sounds like you're trying to increase bandwidth between FreeNAS and your Windows Server? Unfortunately LACP won't help there, it's only useful for multiple clients (and fault tolerance).
If you need more bandwidth I'd recommend looking first at Intel NICs instead of Realtek, then 10GbE or Infiniband if that's not enough.
Sent from my GT-I9300 using Tapatalk 4
Tong
No I just want link agg to work. I broke it again. :( Switch settings back to normal for ports and forced to set manual settings. Tried different ports. Still no go. I had it working for awhile. Rebooting switch broke it too. Also while on LACP only DHCP worked. Manually setting ip would break it.
I just want link agg so more people will get max gb speed. I understand it wont give me more to one link.
Here is something weird after playing around with LACP and other link agg settings, even after deleting lagg, setting switchports to normal, and rebooting both devices, all three of my nic shows same mac with ifconfig.
Tong
here is ifconfig. I have lagg in load balance. Switch ports in normal mode. Plugged only one wire in to the nics. I think my switch freaks if I plug others in since they have same mac?
[root@freenas ~]# ifconfig
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGI
C,LINKSTATE>
        ether 68:1c:a2:12:0a:2f
        inet6 fe80::6a1c:a2ff:fe12:a2f%re0 prefixlen 64 scopeid 0x3
        nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
re1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
C,LINKSTATE>
        inet6 fe80::6a1c:a2ff:fe12:a2f%re1 prefixlen 64 scopeid 0x4
        media: Ethernet autoselect (none)
        status: no carrier
re2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
C,LINKSTATE>
        inet6 fe80::6a1c:a2ff:fe12:a2f%re2 prefixlen 64 scopeid 0x5
        status: no carrier
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x8
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
C,LINKSTATE>
        inet6 fe80::6a1c:a2ff:fe12:a2f%lagg0 prefixlen 64 scopeid 0x9
        inet 192.168.10.118 netmask 0xffffff00 broadcast 192.168.10.255
        status: active
        laggproto loadbalance lagghash l2,l3,l4
        laggport: re2 flags=0<>
        laggport: re1 flags=0<>
        laggport: re0 flags=4<ACTIVE>
[root@freenas ~]#
Tong
Please help guys. Finding two cards with same mac shouldn't happen. I have 3 that matches. Should I play the lotto? Any way to force my network cards to use different mac address? FreeBSD has options but doesn't work on FreeNAS
Uh, you have 3 cards with the same mac because you are using link aggregation....
Tong
I swore I deleted the link agg and rebooted. ifconfig still shows same mac.
Tong
Please check for bugs. I removed member from lagg and rebooted. See ifconfig.
C,LINKSTATE>
        status: active
C,LINKSTATE>
        status: active
re2: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
C,LINKSTATE>
        status: no carrier
C,LINKSTATE>
        status: active
        laggport: re1 flags=4<ACTIVE>
[root@freenas ~]#
jgreco
Resident Grinch
Well the "bug" would appear to be that the ether address for re2 didn't change back; I don't know what the current state of affairs is, but years ago, this kind of thing wasn't that unusual, because hardware was crappy and drivers implemented change-of-MAC through a variety of nefarious strategies (in order to provide UNIX with a more-or-less consistent feature set).
You can manually set a MAC address with "ifconfig re2 ether 12:34:56:78:90:12". It would be interesting to have you do that, reboot, and see if it sticks.
jgreco
Resident Grinch
So are the MAC addresses all the same even after that?
Tong
After a reboot it comes back as the same as link agg mac. These macs use to be all different before I messed with the link agg stuff.
Tong
Deleting the LAGG resets the nic mac for the addin card. My onboard nic required setting manually a different mac. I got very close this weekend. I am able to LAGG the 2 nic ports on the addin card. I used load balance and set switch to use static LAGG for the ports. My computers can ping and access the web page. Everything except the SBS 2k11 for directory services. It is a VM on HyperV 2012 using a LAGG of 3 nics static team.
Other VMs on HypverV host can ping and access FreeNAS web page.
