Limiting open port RST response when using UrBackup
revengineer
FreeNAS 11.3U4.1 reports the following error when using UrBackup:
Aug  7 18:41:57 max kernel: Limiting open port RST response from 372 to 200 packets/sec
Aug  7 18:49:19 max kernel: Limiting open port RST response from 235 to 200 packets/sec
The server is behind a firewall so this is all friendly local traffic. Can I change the allowed limit from 200 to 300 packets? If so, how do I do that?
Samuel Tai
Are you sure about that? If you've created a port forward for 55413 and/or 55414 on your router, you may be seeing hack attempts coming from the Internet.
revengineer
Yes, very certain. Firewall is pfSense running on separate hardware. There is a single open port forwarded to an OpenVPN server and no UPnP. I had more messages like the one above today, and again it was correlated with traffic from a UrBackup client. So is there a way to increase the limit?
Samuel Tai
No, this is unfortunately hard-coded in the kernel. What you can do to silence these notices per the blackhole(4) man page is to set some sysctl tunables:
     sysctl net.inet.tcp.blackhole=2
     sysctl net.inet.udp.blackhole=1
This appears unfortunately due to UrBackup not correctly using TCP.
revengineer
Thank you @Samuel Tai. That would explain why my searches came up empty, although I did not find the hardcoding explicitly stated. I have seen the tunables but they seem to only hide the problem. I am not bothered by the messages, so I will leave as is. I will take this to the UrBAckup forum and ask whether this is a known issue.
revengineer
I set the sysctl tunables above through the web interface under system -> tunables and rebooted the FreeNAS server. I am still getting these messages though. Does anyone know why FreeNAS might be ignoring the tunables?
