Daily security messages
profwalken
need some advice on messages received from my Asrock Board:
SRV-SATURNE.local kernel log messages:
ahcich5: Timeout on slot 27 port 0
ahcich5: is 00000008 cs 00000000 ss 00000000 rs 08000000 tfd 40 serr 00000000 cmd 10009b17
(ada3:ahcich5:0:0:0): READ_FPDMA_QUEUED. ACB: 60 08 98 42 81 40 35 00 00 00 00 00
(ada3:ahcich5:0:0:0): CAM status: Command timeout
(ada3:ahcich5:0:0:0): Retrying command
ipmi0: KCS: Failed to read address
ipmi0: KCS error: 5f
ipmi0: KCS: Reply address mismatch
ipmi0: KCS: Command mismatch
ahcich5: Timeout on slot 8 port 0
ahcich5: is 00000008 cs 00000000 ss 00000000 rs 00000100 tfd 40 serr 00000000 cmd 10008817
(ada3:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 08 c0 a1 50 40 5d 01 00 00 00 00
Limiting closed port RST response from 357 to 200 packets/sec
Limiting closed port RST response from 496 to 200 packets/sec
Limiting closed port RST response from 758 to 200 packets/sec
-- End of security output --
I've already tried to change all sata cables, also switched all ports for hdd with no more result. Board has intel controler one side and marvell the other one, all HDD are
WD RED , system boot on a 120Go ssd mirror.
Messages are concerning always ada3 and also often ipmi0
I've done a RMA change with asrock so the board is new with latest firmware and bios.
If you have any idea on what to check , and do you think it's a big problem or not because i don't see any problem in using the NAS
Pitfrr
I'm using the same motherboard and I experienced similar issues ( CAM status errors) although not completely the same errors.
(da4:umass-sim0:0:0:0): WRITE(10). CDB: 2a 00 00 6b 4c 29 00 00 01 00
(da4:umass-sim0:0:0:0): CAM status: CCB request completed with an error
(da4:umass-sim0:0:0:0): Retrying command
I encountered these errors when using the onboard marvell controllers...
It worked fine with 6 disks (on the intel controller) and when I upgraded from 6 to 8 disks, everything was fine for some months (ok I did have few occurrences of this error but manageable... that is for a backup/test system) but then (all of a sudden) it started to get much more frequent and very annoying (sometime I had two disks dropping out so I went for the M1015 solution!)!!
In your case it could be something else it would bet on the marvell controller. Check on which controller your ada3 is connected to.
profwalken
Thanks for your answer, if we have all the same issue with this MB this is surely a board driver problem on marvell side or with freebsd driver ?
for now i can't check where ada3 is plugged into but is more than sure is on marvell side. I ordered on Amazon a new controller Syba SI-PEX40062 for a very small price 31 €.
When the new controler will be inside , will it be better to put boot drive on it or data drives?
SI-PEX40062
That one also uses a Marvell chipset, and while the Marvell controllers on those Asrock boards are generally more prone to issues, you should IMO avoid any Marvell controller, if 2 ports are enough you can use an Asmedia based controller like the SY-PEX40039, if you need more than 2 ports go with an LSI HBA.
Pitfrr
Yeah, a pity these onboard marvell controllers can't be used/trusted! ;-((
Because that's why this board is so interesting, 12 SATA ports! but it was too late when I heard about those Marvell controllers... :-O
I also considered adding an Asmedia controller but then the price difference with an LSI HBA (granted, a second hand one) was not that big and at least you have something working... (ok, well in my case I may have some issues with the LSI HBA as well, I'll have to dig into it and I might call for help in an other threat! :tongue:)
I found something on Leboncoin, I got mine for 45€ (you can find it a bit cheaper on ebay also)... it's worth to consider (and it's money well spent since they are quite famous and you'll always need one some day! :-D).
profwalken
Pitfrr
Well, I don't know... as I said in the thread, some report the card working well even though being a Marvell controller.
When I started to look into it, I just thought that I didn't want to take the risk and I went the LSI route... I know, not very courageous! :-D
If you already bought it, I'd say, just try it out and see for yourself!
I would just advise not to put all your disks on the Marvell... :tongue: And make sure you have proper backups.
In my case, I had a RAIDz2 pool with 8 drives, I only put 2 drives on the Marvell.
At the beginning, I had issues only with one drive and a reboot solved it. Since I had 2 drive redundancy, it was ok (and since it was my backup system).
But after a while it was very annoying because it was throwing out 2 drives at a time and more frequently, leaving the pool without redundancy and with some checksum errors on the volume. That's when I decided I had enough! :tongue:
profwalken
Ok, so wait and see when controller will be added to MB, i will try to use the controller for the ssd boot mirror and replug data hdd on intel controller side of MB
profwalken
Hi , some news since 10 days i added a new SI-PEX40062 Marvell Controler on MB and moved data hard drive on Intel side, and SSD boot mirror on new marvell everything is allright, no more console messages. Hope it stay like that:)
Pitfrr
Good to know!!
I hope it will work out fine for you. Keep us posted.
