I could not, no matter what, connect to it from a Windows computer. Linux connected just fine but not Windows. I came here for help and found none. Yesterday I decided to dump TrueNAS and go back to Windows but before I did I checked for updates just in case this was a problem that was fixed. I happened to notice the train was a drop down, I never noticed this before. I then selected "Cobia" and upgraded. After the upgrade, I could magically connect from all my Windows computers without issues.
Due to my ignorance concerning how upgrades work I spent countless hours trying to get this to work to no avail. I later found that this problem was caused by an update. How strange that a NAS OS would suddenly break due to an update that rendered the OS useless because it could not perform the one function for which it was designed.
Equally as strange is that no one here was able to point out the simple fix.
Moving forward I've decided to never update unless there is a compelling reason to do so and then only after much research.
I'll leave you guys alone now. Thanks
