I had a working TrueNAS SCALE 22.12.0 system with a Ryzen 2400G CPU.
I upgraded my main PC so now had a spare Ryzen 3900X CPU available which I decided to repurpose by replacing the 2400G in the TrueNAS box.
The 3900X does not have on board video so I needed to install a PCI-e 1x GPU (the only slot available) so I can access the BIOS and/or console if needed. The only card I could buy was an Nvidia GT730 with 4 HDMI outputs.
The problem is now my Emby container wont start - it errors with the following:
So I suspect what is happening is something is detecing the Nvidia GPU, then failing becasue the GPU is ancient.
I've disabled GPU support in Kubernetes Settings, but that had no effect.
Assuming that is the issue, is there a way to either tell Kubernetes to pretend the Nvidia GPU is not there so emby can start, or alternatively install legacy drivers to get past the nvml error?
Error: failed to start container "emby": Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy' nvidia-container-cli: initialization error: nvml error: driver not loaded: unknown
