Im trying to setup jellyfin from a docker hub and not from truenass apps. The reason for it is that I need to use an unique ip for my jellyfin server. Jellyfin is failing to start with an error :
It seems that it's trying to load nvidia drivers but there's basically no gpu in the system. Is there a way to disable gpu support in that jellyfin version? Or is there any other workaround?Error: failed to start container "ix-chart": Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy' nvidia-container-cli: initialization error: nvml error: driver not loaded: unknown
