I'm looking for second opinions on a rather large build. We will be using this as a shared storage for our population analytics clusters, meaning at least 50 (and if it can handle it, 250+) nodes potentially all writing at once, over NFS. Extremely random sync writes, several TB of data each day.
MB - 1x- Supermicro X10DRC-T4+
CPU - 2x - Xeon E5-2687W v3
RAM - 12x (384GB total) - Samsung M386A4G40DM0-CPB
Chassis - 1x - Supermicro SC847BE1C-R1K28LPB
External HBA - 1x - LSI00343 9300-8e
JBOD - 1x - Supermicro SC847E16-R1K28JBOD
HDD - 81x - HGST Deskstar NAS 6TB H3IKNAS600012872SN
SLOG - 2x (mirrored) - Intel P3700 400GB NVMe SSD
We were planning to set up the HDDs with 9x 8-disk raidz2 vdevs, leaving 9 for warm spares and yielding 324TB after parity. Our IT department doesn't want to have to constantly be changing out drives, hence the large number of spares. Would raidz3 be a better use of these drives, potentially running in a degraded state for an extended period?
The OS will probably be installed on a SATA DOM, or reduce the spares by two and use two mirrored HDDs. We haven't really decided yet.
For the SLOG, is the P3700 considered reliable enough that we don't need to mirror it? I would hate to lose 300TB+ just because we wanted to save $1200.
Based on the theoretical throughput of the 4x 10Gb network (I know I won't actually get this, and likely won't set up the network in this way), 10 seconds (two transactions) of network writes would be 50GB, leaving quite a bit of extra space on the P3700. If we give 100GB for the SLOG (extra space for potential local writes and to improve IOPS), is it problematic (or even worth it) to use the other 300GB as L2ARC?
We do not plan on using deduplication, but do plan on enabling compression. I know the general recommendation is to give as much ram as possible; at least 1GB for every 1TB of storage. Would going higher than 384GB give us a significant performance boost? With those ram modules, we could go as high as 768GB.
I know this is a FreeNAS forum, and I could not find the hardware above in the FreeBSD 9.3 hardware compatibility list. I did a search, though, and found at least one other person using that motherboard, so I am confused if this will work with FreeNAS 9.3. If not, you guys are still the most knowledgeable ZFS people I could find, and I hope you would still be willing to discuss if I have to go to a later version of pure FreeBSD.
