Lagg w. Failover and VLANS failing
Jason Brooks
I have been playing with the ability to have redundant interfaces, but ran into a problem.
  1. build link aggregation (failover mode) of em0 and em1 -> LAGG0
  2. build vlans(100,999) using parent interface of LAGG0
  3. assign ip addresses to vlan interfaces
When the first vlan is setup with an ip address, pinging and failover work. However when I add the second ip address to the second vlan, the first vlan stops working, but the second vlan does still work. This is regardless of which network connection is active. It's as if setting up a new vlan ip address clobbers the previous ones.
The output of ifconfig shows LAGG0 having em0 and em1 as members. when I add the second vlan (vlan999) and it's ip address, ifconfig's output for vlan100 changes: vlan: 100 goes to vlan:0 and Parent interface goes from lagg0 to <none>.
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=4019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLAN_HWTSO>
        ether 00:15:17:cb:8a:30
        media: Ethernet autoselect
        status: no carrier
em1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 00:15:17:cb:8a:31
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
bce0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=c01bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,VLAN_HWTSO,LINKSTATE>
        ether 00:21:5a:af:77:00
        inet 192.168.1.28 netmask 0xffffff00 broadcast 192.168.1.255
        status: active
bce1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        status: active
vlan100: flags=8803<UP,BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=103<RXCSUM,TXCSUM,TSO4>
        ether 00:00:00:00:00:00
        inet 10.37.50.29 netmask 0xffffff00 broadcast 10.37.50.255
        vlan: 0 parent interface: <none>
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        status: active
        laggproto failover lagghash l2,l3,l4
        laggport: bce1 flags=0<>
        laggport: em1 flags=5<MASTER,ACTIVE>
vlan999: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        inet 192.168.3.29 netmask 0xffffff00 broadcast 192.168.3.255
        status: active
        vlan: 999 parent interface: lagg0
This also happens if I use interfaces em1 and bce1.
So I ran some tests to see if I was configuring link aggregation and vlans correctly:
First I tried just setting up two ethernet interfaces with link aggregation (failover mode) with success.
  • setup lagg0 with em0 and em1 as members
  • tested failover worked...
Then tore down the link aggregation to test vlans:
Setup em0
  • added vlan100 (interface ip: 10.37.50.29/24)
  • added vlan999 (interface ip: 192.168.3.29/24)
  • pinging ip addresses on the lans works.
System specific information:
FreeBSD 9.3-RELEASE-p28 amd64
running on an HP Proliant DL360G5.
Is this a bug, or am I doing it wrong?
jgreco
Resident Grinch
You're doing it wrong; do not mix interface types. Either use the em's OR the bce's, don't mix.
There looks like another issue here but I'm not interested in trying to troubleshoot with a broken configuration. I'm one of only a few people here who's worked with layered network configs like this, and I'll tell you that getting the basics right helps.
Jason Brooks
Actually, that's the first way it failed: I used em0 and em1 and got exactly the same error. So I will start again with em0 and em1 and show you the output of ifconfig for each step. For entries that don't change such as em0 and em1, I will leave them out of subsequent entries.
First step: nothing setup: em0 and em1 are plugged into the switch. bce0 is my network connection on default vlan0
        status: active
        status: active
        status: active
        ether 00:21:5a:af:67:f0
        media: Ethernet autoselect (none)
        status: no carrier
Second Step: lagg0 configured with em0 and em1
  • em1 difference: mac address altered to match em0 and
        status: active
        laggport: em1 flags=0<>
        laggport: em0 flags=5<MASTER,ACTIVE>
Third Step: addition of vlan100 and vlan999
vlan100: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
vlan999: flags=8842<BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        status: active
Note how vlan 100 no longer appears with parent interface of lagg0. (It did start configured as it was the first entry I made.) BUT here is a screen shot of the configured vlans:
And now, I go and configure vlan100 and the relevent lines become:
vlan999: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
vlan100: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        inet 10.37.50.28 netmask 0xffffff00 broadcast 10.37.50.255
        status: active
        vlan: 100 parent interface: lagg0
Note how vlan999 and vlan100 switched places. The vlan screen did not change but here's a screen shot of the configured interfaces:
So if my configuration is wrong, I would be happy to fix it but it's not at all clear in the documentation how to do this, and it appears something is wrong with how the gui is configuring freebsd.
--jason
Can you attach a debug file? System -> Advanced -> Save debug?
jgreco
Resident Grinch
Yeah, I'd say the middleware is hamfisting the vlan configuration. To be fair, configuring vlans is kind of finicky so I'm guessing that whoever twiddled those lines of code probably never actually tried it :smile:
So what happens if you do "ifconfig vlan999 vlan 999 vlandev lagg0"?
Jason Brooks
Yeah, I'd say the middleware is hamfisting the vlan configuration. To be fair, configuring vlans is kind of finicky so I'm guessing that whoever twiddled those lines of code probably never actually tried it :)
This change:
        status: active
So I went ahead and configured vlan999 in the gui and the vlan100 configuration was stepped on. I modified your idea: I entered and got the following: (both vlans and lagg0 shown):
ifconfig vlan100 vlan 100 vlandev lagg0
        status: active
        status: active
        inet 192.168.3.28 netmask 0xffffff00 broadcast 192.168.3.255
        status: active
And both vlans work!
--jason
jgreco
Resident Grinch
You can do that, but what's going to happen is that any change to networking which causes the system to "reconfigure" is likely to stomp it. There's no post-network-reconf script hook.
jgreco
Resident Grinch
I'd say that's probably a good idea. Include a link to the thread, and post the issue number here, please.
Jason Brooks
I should add though that rebooting the system after configuration brought the lagg0 and vlan interfaces up and running correctly.
jgreco
Resident Grinch
Well, that's better, but I think the network reconfiguration hook has a tendency to deconfigure-and-reconfigure things (possibly unnecessarily) when changes are made to networking, and of course it shouldn't go dead or deaf.
jgreco
Resident Grinch
Not a problem, with enough patience we usually get people sorted out.
