Adrian
- Jun 29, 2011
I have been bitten by this on 2 of my 3 dual NIC machines.
On a reboot a lagg interface may change which interface is the master.
If you are using DHCP it is wise to ensure that all the physical interface MAC address are given the same static DHCP IP address and host name, otherwise the lagg may gain an unexpected IP address, casing confusion and woe.
In this example of a flipped and fixed lagg, igb0 in under 11.2-U7 and previous igb0 had always been the master. I have not yet noticed a lagg flipping back.
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: member of lagg0
options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether d0:50:99:c2:35:ec
hwaddr d0:50:99:c2:35:eb
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
hwaddr d0:50:99:c2:35:ec
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: lagg0
inet 192.168.1.50 netmask 0xffffff00 broadcast 192.168.1.255
status: active
groups: lagg
laggproto failover lagghash l2,l3,l4
laggport: igb0 flags=0<>
laggport: igb1 flags=5<MASTER,ACTIVE>
