Elliot Dierksen
- Dec 29, 2014
I am running FreeNAS-9.3-STABLE-201412240734 on an HP DL380 G5. I recently added the following 10G NIC to increase performance.
bxe0@pci0:11:0:0: class=0x020000 card=0x121314e4 chip=0x166214e4 rev=0x01
hdr=0x00
vendor = 'Broadcom Corporation'
device = 'NetXtreme II BCM57712 10 Gigabit Ethernet'
class = network
subclass = ethernet
bxe1@pci0:11:0:1: class=0x020000 card=0x121314e4 chip=0x166214e4 rev=0x01
hdr=0x00
class = network
subclass = ethernet
These NIC's connect to the following switch:
HP Comware Platform Software
Comware Software, Version 5.20.105, Release 1809P01
Copyright (c) 2010-2014 Hewlett-Packard Development Company, L.P.
HP 5820X-14XG-SFP+ Switch with 2 Interface Slots uptime is 0 week, 1 day, 15 hours, 16 minutes
HP 5820X-14XG-SFP+ Switch with 2 Interface Slots with 2 Processors
1024M bytes SDRAM
4M bytes Nor Flash Memory
512M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is Ver.B
CPLDA Version is 003, CPLDB Version is 003
BootRom Version is 301
[SubSlot 0] 14SFP Plus+4GE Hardware Version is Ver.B
[SubSlot 1] No Module
[SubSlot 2] No Module
[SubSlot 3] No Module
This server also has 4 gigabit ports as follows:
em0@pci0:6:0:0: class=0x020000 card=0x7044103c chip=0x105e8086 rev=0x06 hdr=0x00
vendor = 'Intel Corporation'
device = '82571EB Gigabit Ethernet Controller'
class = network
subclass = ethernet
em1@pci0:6:0:1: class=0x020000 card=0x7044103c chip=0x105e8086 rev=0x06 hdr=0x00
class = network
subclass = ethernet
bce0@pci0:3:0:0: class=0x020000 card=0x7038103c chip=0x164c14e4 rev=0x12
hdr=0x00
device = 'NetXtreme II BCM5708 Gigabit Ethernet'
class = network
subclass = ethernet
bce1@pci0:5:0:0: class=0x020000 card=0x7038103c chip=0x164c14e4 rev=0x12
hdr=0x00
class = network
subclass = ethernet
These NIC's connect via an LACP LAG to this switch:
HP ProCurve 2848
Image stamp: /sw/code/build/mako
Sep 24 2013 16:28:07
I.10.103
1674
Boot Image: Primary
The twisted pair NIC's are all configured as an LACP LAG, and that works fine. I attempted to configure the two 10G ports as a LAG, but I cannot get that to work. The switch reports that it sees the successful LACP neogtiation, and I think it even learned a MAC address, but FreeNAS reports the LAG interface as down. I tried a number of combinations, but nothing was successful. I can get it to work when I configure it as static and the switch side and FEC on the FreeNAS side. I would really prefer to have LACP work. I am not very familiar with the CommWorks (H2C) flavor of switch, but I can gather any other information that might be relevant. Any suggestions?
hdr=0x00
class = network
subclass = ethernet
hdr=0x00
class = network
subclass = ethernet
1024M bytes SDRAM
class = network
subclass = ethernet
class = network
subclass = ethernet
hdr=0x00
class = network
subclass = ethernet
hdr=0x00
class = network
subclass = ethernet
HP ProCurve 2848
I.10.103
1674
Boot Image: Primary
