I have added a second SCALE box to my network and run into an unexpected problem as a result. Both are running 22.02 RC2. Everything works fine with the first machine set up with its LACP link, addressed via DHCP. When setting up this system, I noted that SCALE creates its own MAC address for the LACP link (as discussed in Jira issue NAS-112401) but didn't think much of it after updating my DHCP static mapping. This is what that looks like to my switch (lg2 is the link to the first box). Note the MAC address ending in 4333:
The issue came when I switched the second SCALE box over from a single link to LACP. As you might have guessed by now, its LACP link has the same MAC address as the first box. Both are on the same VLAN and this creates havoc with the DHCP server making both machines inaccessible. From my switch's perspective, the 4333 MAC bounces back and forth between lg2 and lg3, with the MAC table oscillating between the following over time:
or
From the NAS-112401 Jira issue, it sounds like the Core behavior was for the LACP interface to adopt the MAC of one of the member interfaces, which would avoid this issue. My questions are therefore:
Let me know if I can provide any additional information to help get to the bottom of this and thanks in advance.
SSH@coresw#show mac-address Total active entries from all ports = 40 MAC-Address Port Type VLAN 3cec.ef0d.2112 lg2 Dynamic 10 3cec.ef0d.2113 lg2 Dynamic 10 3ef6.d99a.4333 lg2 Dynamic 10
SSH@coresw#show mac-address Total active entries from all ports = 38 MAC-Address Port Type VLAN 3cec.ef0d.2112 lg2 Dynamic 10 3cec.ef0d.2113 lg2 Dynamic 10 3ef6.d99a.4333 lg3 Dynamic 10
or
SSH@coresw#show mac-address Total active entries from all ports = 40 MAC-Address Port Type VLAN 0cc4.7a9d.80a0 lg3 Dynamic 10 0cc4.7a9d.80a1 lg3 Dynamic 10 3cec.ef0d.2112 lg2 Dynamic 10 3cec.ef0d.2113 lg2 Dynamic 10 3ef6.d99a.4333 lg2 Dynamic 10
- Is there a plan to implement some type of MAC address randomization or promotion so I can have multiple SCALE boxes with LACP and DHCP working on the same VLAN?
- Is there a way to change the virtual MAC of the LACP link either through the TrueNAS console or in Linux itself (such that it won't get reverted after a reboot/update)?
